hi so after much research into the cause of files that are too large or take up too much memory i have found two scripts that do the heavy lifting for cleaning out a max file. i was hoping there was a way of combining them into one maxscript i can run from the tool bar. I don't know that much but i do know the following does not work:
please help
macroScript Clean
category:"Clean"
toolTip:"Clean"
buttonText:"Clean"
t=trackviewnodes;n=t[#Anim_Layer_Control_Manager];deleteTrackViewController t n.controller;gc()
t=trackviewnodes;n=t[#Max_MotionClip_Manager];deleteTrackViewController t n.controller;gc()
@3dwannabI know this thread
@3dwannab
I know this thread is kind of old but a recent post at AreaMax led me here.
This is potentially a useful script. I did run it on a 98mb file in Max 2020 and it increased the file size to 324mb. I wonder if this script is incompatible with Max's newer code? Have you tried the script on a newer version of Max?
Edit: I tried the script on two other files and both grew in size about 3X. Just wanted to make sure it wasn't an anomaly with that one file.
Are you tried this tool
http://www.scriptspot.com/3ds-max/scripts/cleaner
i have, but these two scripts do more to clean my bloated files then that script does.
Use code below
Or (Clean Motion Clips, Layer Controls + Retimer Managers)
