Check Meshes For 2nd UV Channel
By Miles · 2016-12-27
I'm in of a bit of a pinch got a lot of objects in a scene looking to export out into a engine. Seems I miss giving some objects UV's. Would need to figure a way to get a list of what objects don't have a second UV channel for light maps.
vusta
i hacked this...
http://forums.cgsociety.org/archive/index.php?t-264514.html
to get this: so you see if there's less than the 2 default channels (0 for vc and 1 as the default UV) the objects will be selected...ie. hasn't got an extra 'light map' channel....again, I STRESS, I hacked this...okay...cos it was really old...2005...and I'm not a mxs expert...
fn getNumUVChannels obj = (
count = 0
if classof obj == Editable_Poly then
for i in 1 to polyOp.getNumMaps obj do
if polyOp.getMapSupport obj i then count += 1
if classof obj == editable_mesh then
for i in 1 to meshOp.getNumMaps obj do
if meshOp.getMapSupport obj i then count += 1
return count
for o in geometry do
if getNumUVChannels o < 2 then (
selectmore o
