Change visibility after particle collision
By vic · 2012-07-26
Hi all:
First of all, thanks to everyone for the opportunity to join and participate. I am not a scripter, I just work on a "trial-error" basis, but I hope to learn more as I interact here with you.
The idea of the particle system I am working in is as follows:
1. The scene includes some objects that I want to "turn into" particles.
2. The PF system takes these objects (which are renamed conveniently) and using a birth script, it generates one particle per object, the same position and geometry as the original object. This has been taken from Alan McKay's tutorial here http://vimeo.com/11100227 and slightly modified. It works fine.
This is the code of the birth script
on ChannelsUsed pCont do
	 pCont.useAge = true
	 pCont.useTM = true
	 pCont.useShape = true
on Init pCont do
	GLOBAL whatever = $whatever* as array
on Proceed pCont do
	t=pCont.getTimeStart () as float
	if t < 0 do
		for i=1 to whatever.count do
			pCont.addParticle()
			pCont.particleIndex =pCont.numparticles()
			pCont.particleAge = 0
			pCont.particleTM = whatever[i].transform
			pCont.particleShape = whatever[i].mesh
on Release pCont do
3. A collision event sends particles to another event, where geometry is displayed. The problem is the following: I want to hide the geometry of the original objects, and I don't know how. I have tried visibility parameter both in the birth script and in a separate script operator located in the second event, and the objects turn invisible at frame 0, not after collision event.
Any help or idea on this will be a great help. Thanks in advance to everyone!
Vic
Willian Kim
I hope it helps you link ... but I do not really understand what you want to do ... just make objects base invisible ? I did some more testing has not got a good result ... If I have anything post here
Thanks a lot kimarotta! Thanks for the link! It will take some time for me to study it but for sure it will help :-)
