Change selected plane size and keep pivot in place
By titane357 · 2020-12-10
I tried to make a script to change a plane size keeping its pivot at the same place.
Of course my script works just in one case, it don't take in account plane rotation, and is not interactive... yes I'm bad scripter.
If someone have time and is interrested, I'd so happy. Thanks a lot.
	obj = selection[1]
	scaleX = 2
	scaleY = 3
	scaleZ = 1
	in coordsys obj.transform
		scale obj [scaleX, scaleY, scaleZ]
You will have to find proper values of scaleX and scaleY.
Reply to miauu
titane357
Hi, thanks for answer.
But I wanted to keep plane as a plane object.
I tried this :
OBJ = selection[1]
MIDD = ( OBJ.max + OBJ.min ) /2
POS = OBJ.pos
DIST = distance MIDD POS
OLDL =OBJ.length
OLDW=OBJ.width
	try destroyDialog rlslice catch()
	global rlslice = rollout rlslice ""
		spinner spL "LENGHT " width:90 range:[0.001,10000,OLDL] type:#float pos:[55,5]
		spinner spW "WIDTH " width:90 range:[0.001,10000,OLDW] type:#float pos:[55,25]
		button butconnect "GO" pos:[2,2]
		on butconnect pressed do
		OBJ.length = spL.value
		OBJ.width = spW.value
		OBJ.pos = [ OBJ.pos.x + ( OBJ.width- OLDW )/2 , OBJ.pos.y - ( OBJ.length - OLDL )/2 , OBJ.pos.z ]
		OBJ.pivot = POS
createDialog rlslice 160 130
but it work just in some cases, ( with pivot at top left of the plane for eg ) I'm not only bad scripter but a noob in maths...
Reply to titane357
		spinner spL "LENGHT " width:130 range:[0.001,10000,10] type:#worldUnits pos:[5,5]
		spinner spW "WIDTH " width:130 range:[0.001,10000,10] type:#worldUnits pos:[5,25]
		on spL changed val do
			if classof (curO = selection[1]) == Plane do
				curO.length = val
		on spW changed val do
				curO.width = val
		on rlslice open do
				spL.value = curO.length
				spW.value = curO.width
