Hi all.
Does anyone have, or know of, or is capable of producing the following idea?
A script that when you click on a piece of geometry, it creates a camera offset from that point at a distance of either that can be chosen by the user, in an axis chosen by the user.
The idea being it would be a quick process to create a camera, at eye level, on a landscape.
Cheers.
see if that helps you...
Update...
--- Work with Standard cam and Vray Cam
--- Link Target with Obj
--- Name Cam
Not quite.....
Hello and thanks you for this script.
I'm afraid it's not quite what i'm after. I was hoping for something that lest you click on any part of the target object. I know that's a bit more complicated but yours only puts the camera in relation to the target objects pivot point.
Is this something you think you can add in?
still do not quite understand ...
something like autogrid Target Cam?
