Blur transparency map
By titane357 · 2009-03-20
Hello
I have some slowdown with Vray when using Transparency map.
I need to set blur to 0.01, I know "111_massFiltering" script but I need to blur just transparency map.
Anybody have done this ? Thanks :-)))
Christopher Grant
Actually you don't need to change the blur value - just need to turn off opacity map filtering. Here's a little script that will do just that - remove opacity map filtering on standard & vray mats. Its really simple, you just select your objects and then go to Maxscript / Run Script and run the attached file.
 Note: this script requires some code that part of Neil Blevins' script pack so you'll need to download and install his script pack first.
Neil's pack:http://www.neilblevins.com/soulburnscripts/SoulCollection_v047.zip
Install instructions:http://www.neilblevins.com/soulburnscripts/soulburnscripts.htm
Then download / run my script in attachment area below.
