Does anyone know wether bitmap collector by neil belvin works with 2013 or is there another script, or a way within max to copy all bitmaps and place them within one folder ?
Cheers
Bitmap collector
By brit · 2012-09-12
try this code
How to use:
1.run the copySceneBmp function
2.next you can run simply
copySceneBmp()
then pick folder where you want to store bitmaps or you can runcopySceneBmp toDir:@"C:\Temp"
(specyfy your path if you not use @"C:\Temp") and thats it.fn copySceneBmp toDir: =
local usedSceneBitmaps = (getClassInstances bitmaptex)
local bmpPats = #()
local SIOFile = dotNetClass "System.IO.File"
local SIOPath = dotNetClass "System.IO.Path"
if usedSceneBitmaps.count != 0 do
for b in usedSceneBitmaps do
if bmpPats.count == 0 then append bmpPats b.filename else
--next line this method performs a lower case comparison of strings
--is more precise then *appendIfUnique*
if (for i = 1 to bmpPats.count where stricmp bmpPats[i] b.filename == 0 collect i).count == 0 do
if bmpPats.count != 0 do
targetDir = if toDir != unsupplied then toDir else (getsavepath caption:"Select the folder for bitmaps")
if targetDir != undefined do
for sFile in bmpPats do
tFile = targetDir +"\\"+(SIOPath.GetFileName sFile)
SIOFile.Copy sFile tFile
free bmpPats ; free usedSceneBitmaps
nice and simple.
would you explain the dotnet part. how it is helping to copy the file.often files are not in the exact path but in some other asset path. how the script is handling this.sorry for bothering with basic questions.thanks
i use dotnet in this case in combinations with mxs for comparation, but you can use
mxs only.dotnet have more powerful comparation methods (see code here http://www.scriptspot.com/3ds-max/scripts/scriptrun).About asset path, this code will skip all missing paths.
maybe http://www.scriptspot.com/3ds-max/scripts/asset-collector
