Biped activate Mixer Mode
By titane357 · 2024-09-26
I would like to know how to activate or deactivate Biped Mixer Mode by script.
Thanks ! :-)
Comments (8)
titane357
Thank you very much ! It is what I needed
I just "made" a little script as always in frankenstein style.
The marvelous fonction is from ZalitZ
If it can be helpfull to somebody.
Script : Toggle Mixer Mode from the selected skinned mesh.
----by ZalitZ
fn ListSkinBones obj toNode:false =
    skinMod
    bonesList = #()
    result
    clearSelection()
    max modify mode
    hiddenState = obj.ishidden
    obj.ishidden = false
    select obj
    skinMod = obj.modifiers[#skin]
    modPanel.setCurrentObject obj.modifiers[#Skin]
    bonesList = for i=1 to (skinOps.GetNumberBones skinMod) collect (skinOps.GetBoneName skinMod i 0)
    obj.ishidden = hiddenState
    result = bonesList
    if toNode == true do
        result = for i in bonesList collect (getNodebyName(i) )
    result
SELM = $
ALLB = (ListSkinBones $ toNode:true)
select ( for a in ALLB where (  matchPattern a.name pattern:("*"+ "Pelvis" + "*")) collect a)
select ( $.parent)
biped_ctrl=$.controller
if biped_ctrl.mixerMode == on then biped_ctrl.mixerMode = off else biped_ctrl.mixerMode = on
select SELM
max zoomext sel
Reply to titane357
Simon Bourgeois
You're welcome
Here is an optimized version of your script
	fn GetPelvisBones obj =
		local pelvis
		local skinMod = obj.modifiers[#skin]
		local bonesList = for i=1 to (skinOps.GetNumberBones skinMod) collect (skinOps.GetBoneName skinMod i 0)
		local pelvisbone = for a in bonesList where (matchPattern a pattern:("*"+ "Pelvis" + "*")) collect a
		pelvis = getNodebyName pelvisbone[1]
	with redraw off
		max create mode
		local SELM = selection[1]
		local hiddenState = SELM.ishidden
		local pelvisB = GetPelvisBones SELM
		local bip = pelvisB.parent
		local biped_ctrl=bip.controller
		if hiddenState == true then (SELM.ishidden = false;max zoomext sel;SELM.ishidden = true)
		else max zoomext sel
		--max modify mode --optional much faster without it but you can uncomment if you need to be on modify panel
	redrawviews()
I've removed some "select" stuff that wasn't needed, also removed all the "hidden"check stuff from the function, and add it back in the end to ensure that the zoom on selection at the end works even if the selected object is hidden (it could be selected in the layer manager but hidden in the viewport), i've put the "pelvis search into the function to avoid creating two arrays with all the bones names and nodes, you only needed the pelvis to be returned by the function, adding "max create mode" makes it much faster as in this case you don't need to be in modify mode (sometimes it is required, but not in this case).Declaring every variable as local is not neccessary in this case if all the code is within parentheses, but i like to do so anyway, it is more for clarity and readability. In your code, variables were just declared without being within parentheses, it was creating some global variables that can be problematic in certain case, enclosing your code within parentheses avoid creating global variables as maxscript automatically declare variable as local if within parentheses. I also added a redraw off to even further speed up the process ;)
Reply to Simon Bourgeois
titane357
Hi ! Thank you very much !
But a ")" is missing at the end ;-)
I think I'll never do a clean script in my all life...
In some cases, I get :
-- MAXScript FileIn Exception:
-- Unknown property: "mixerMode" in Controller:Position_Rotation_Scale
( with RenderPeople rigged )
Reply to titane357
Simon Bourgeois
you're welcome
Don't worry i am kind of messy too, I try to get better at it ... There is always stuff to learn...
In fact it wasn't a missing ")" at the end, but it was an extra "("at the begining, before the beginning of the function GetPelvisBones.;)
I've check the "RenderPeople rigged" setup and the problem comes from the fact that the pelvis object isn't included in the skin modifier so the function return undefined, you can add the pelvis to the skinmodifier, the script will work fine...
but i came up with something that will work even on RenderPeople rigged characters:
	fn getParents o Arr=
        try (
				if o.parent != undefined then
					appendifunique Arr o.parent
					getParents o.parent Arr
				else appendifunique Arr o
			)catch()
	fn getChildren o Arr=
		try (
				if o.children != undefined do
					join Arr o.children
					for child in o.children do(for i = 1 to child.children.count do getChildren child.children[i] Arr)
			)catch()
	fn ParentsAndChildren obj =
		local resultArr=#()
		getParents obj resultArr
		getChildren obj resultArr
		makeUniqueArray resultArr
		resultArr
	fn GetBip obj =
		local bone1 = skinOps.GetBoneName skinMod 1 0
		local AllHierarchy = ParentsAndChildren (getNodeByName bone1)
		local bipbone
		for o in AllHierarchy where o.controller != undefined and hasproperty o.controller #mixerMode do bipbone = o
		bipbone
	with redraw off
		max create mode
		local bip = GetBip SELM
	redrawviews()
in this version i collect all bones hierarchy even if they aren't in the skin modifier and then i filter only the one that has a "mixerMode" property, this way it will likely work in most cases, i hope...
the way i build the hierachy array could surely be better written, but it works...
titane357
Hi Simon.
Thank you very much again !
Now it works like a charm !
I think I can live with the hierarchy array as it is written :-)
Best
Reply to titane357
Simon Bourgeois
You're welcome
Me too :)
if you apply the script to an object that doesn't have any skin modifier it crashes, so here is a modified version, it will return a warning message instead of crashing:
        try (
			)catch()
		try (
					join Arr o.children
			)catch()
		local resultArr=#()
		resultArr
	fn GetBip obj =
		local bipbone
		if skinMod != undefined then
		)else (messagebox "Please Select an object with a Skin modifier"beep:off;return undefined)
		bipbone
	with redraw off
		max create mode
		if bip != undefined do
	redrawviews()
Simon Bourgeois
You can use this:
	for bip in selection do --assuming you have the root bip selected
		biped_ctrl.mixerMode = on --or off
--or
	biped_ctrl=$bip01.controller --where bip01 is the  root bip name
