better bridge
By SMFoged · 2010-02-25
A couple of people have noticed some limitations in the bridge command.
http://area.autodesk.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-ma…
I put up a solution involving csPolyTools and a macro.
This macro is a little slow, but otherwise works great.
I can not code scripts my self, so if anyone feels like having a shot at creating a better bridge I would appreciate it.
good luck.
Stephen
Petrine Kristiansen
Yes this is what we’re waiting for years. I am thankful this is successfully implemented.
real08121985
I've created a little macro with the help of the macrorecorder, nothing special. Just drag'n'drop the macro in the 3ds max viewport. You can find the macro under "Customize > Customize User Interface > Category: Editable Polygon Object > PolyBridge"
I have tested the macro, it should work with editpoly-objects as well as with editpoly-modifiers. Maybe you want to play around with it a bit. I don't know if it's what you're searching for, hope it helps :)
Reply to real08121985
SMFoged
This is awesome!
Almost what i was looking for.
It is much faster than my macro solution, but i see one little place where it could be improved.
It can not bridge two edges that share a vertex and form a V.
Thanks for the good effort.
/Stephen
