Batch saveto previous
By phil · 2014-06-05
I'm thinking this may be simple, but have absolutely no maxscript skills whatsoever. I have a bunch of files saved in Max 2015, and I'd like to save them all back - as copies - to max 2013 versions. Anyone?
Thanks,
Phil
Comments (8)
Edward Snowden
How to add a custom script into this batch processing?
May I ask something about this batch processing.
I've got many *.max file in library that was provided as 2012 but actually was saved from higher version, so when use them in Xref object and Xref scene, annoying popup always display "Missing Dlls" - (which is nothing useful missing actually, just some higher Max dependencies left in those files).
I've found script to "remove missing dlls" and I've found this batch lower version save-as. How to combine them together for a batch processing which remove-missing-dlls message and save-as to lower version? Or how to execute other *.ms file in the time this batch perform action?
Saving time for anyone would combine these 2 function, the remove missing plugin script is the one by M. Breidt (martin@breidt.net)was largely published in web. Code below.
	-- get list of missing plugin classes
	str = stringStream ""
	apropos "*missing*" to:str
	seek str 0
	cls = #()
	while not (eof str) do (
		ln = readLine str
		tk = filterString ln " "
		if tk.count == 4 then (
			clsName = tk[1]
			try (
				val = (execute clsName)
				sc = superClassOf val
				-- Alternative: check for .classID == #(-1,0)
				if sc==MAXWrapper or sc==node or sc==material or sc==MAXWrapperNonRefTarg then (
					append cls val
					format "%: %\n" c val
				) else (
					format "Skipping % (%)\n" val sc
			) catch (
				format "Cannot use % for searching missing plugins.\n" clsName
		) else (
			format "Incorrect string found in missing plugin name list: %\n" tk
	-- now search for instances of those missing plugins
	c = 0
	foundMissing = #()
	for j = 1 to cls.count do (
		cc = cls[j]
		ci = getClassInstances cc
		if ci.count > 0 then (
			format "%: Found % instances of %: %\n" j ci.count cc ci
			for i = 1 to ci.count do (
				-- get current class
				myClass = classOf cc
				append foundMissing myClass
				-- get list of all subclasses
				allClasses = myClass.classes
				for k = 1 to allClasses.count do (
					-- search for useful replacement
					if allClasses[k].creatable then (
						-- create new instance of default (first) class
						newInst = createInstance allClasses[k]
						try (
							-- replace all instances (requires 3ds Max 2008+ or AVG extensions)
							q = replaceInstances ci[i] newInst
							c += 1
							-- and exit for k loop
							exit
						) catch (
							format "Error replacing %\n" ci[i]
							format "Exception: %\n" (getCurrentException())
				) -- end: for k
				-- todo: what happens if NO useful replacement was found?
			) -- end: for i
		) -- end: if
	) -- end: for j
	if c > 0 then (
		-- produce summary message for user
		str = "Replaced "
		append str (c as string)
		append str " missing plugin(s) with default objects:\n"
		for i in foundMissing do (
			append str "\t"
			append str (i as string)
			append str "\n"
		append str "\nUSE RESULT WITH CAUTION!\nSAVE TO A DIFFERENT FILE NAME!"
		messageBox str title:"removeMissingPlugins v0.1" beep:true
		print foundMissing
	) else (
		messageBox "No missing plugins found" title:"removeMissingPlugins v0.1"
Thanks miauu & lightcube for given script.
I can't test it, so you have to do it.
-- Created: 		14-06-2014
-- Last Updated:	05-12-2015
-- Version:			1.10
-- Author :  Kostadin Kotev / miau_u@yahoo.com / http://miauumaxscript.blogspot.com/
-- Version:  3ds max 2009 (10) (should work in older versions too!)
-- Version 1.10 (functions added by Shawn Olson / http://www.shawnolson.net )
-- Added drop down to choose Max versions that the current Max can save to
-- Added checkbox to make the copying of files optional. Copy is off, overwrites original files.
-- Discription: Batch save selected MAX files to previous versions and optionally make copy
-- Usage: RUN IT
-- Wishlist:
-- MODIFY THIS AT YOUR OWN RISK
-- macroscript miauuBatchSaveAsPrevious
-- category:"miauu"
-- tooltip:"Batch SaveAsPrevious"
-- buttonText:"Batch SaveAsPrevious"
	global rol_miauuBatchLoadXRefScenes
    try(destroyDialog rol_miauuBatchLoadXRefScenes)catch()
    rollout rol_miauuBatchLoadXRefScenes "miauu's Batch Save As Previous" width:405 height:291
		local ConvertClass = dotnetclass "system.convert"
		local ImageClass = dotnetclass "system.drawing.image"
		local logoIcon = "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"
		local curMaxVersion = ((maxVersion())[1] / 1000)
		local openFileRoll = dotNetObject "System.Windows.Forms.OpenFileDialog"
        local disableForeColor = (dotNetClass "System.Drawing.Color").white
        local maxFiles = #()
		function versionNums = (
			local longVersion = ((curMaxVersion - 2) + 2000)
			for i = 1 to 3 collect (longVersion - (1 * i))
		local versions = versionNums() -- array of versions the current version of Max can save to.
    	dotNetControl lv_Batch "system.windows.forms.listView" pos:[10,10] width:273 height:200
    	button btn_getDir "Get Directory" pos:[290,10] width:108 height:21 toolTip:"Select all .max files in the given folder and/or its sub-folders"
    	button btn_getFile "Get file(s)" pos:[290,35] width:108 height:21 toolTip:"Select one or multiple files in given folder"
    	button btn_Clear "Clear" pos:[290,60] width:108 height:21
    	dropdownList ddl_version "Save to Version" pos:[295,223] width:96 height:40 items:(for v in versions collect v as string)
    	checkbox chkBox_showFullPath "Show Full Path" pos:[10,215] width:95 height:15
    	label lbl_select "Select:" pos:[120,215] width:33 height:13
    	button btn_all "All" pos:[157,214] width:40 height:18
    	button btn_none "None" pos:[200,214] width:40 height:18
    	button btn_invert "Invert" pos:[243,214] width:40 height:18
    	button bnt_saveAsPrevious "Save as previous" pos:[9,235] width:276 height:30
    	HyperLink http_miauu "miauu's MaxScripts" pos:[300,270] width:90 height:15 address:"http://miauumaxscript.blogspot.com/" color:(color 7 231 251)
    	progressBar pb_xRefprogress "" pos:[10,270] width:275 height:14 value:0 color:(color 0 255 0)
    	checkbox chk_Copy "Make Copy" pos:[300,204] width:90 height:16 checked:true tooltip:"When off, overwrites the original file."
		--	Credits to Peter Addington - http://lonerobot.net/?p=314
		function String2Bmp string =
			local clipboardClass = dotNetClass "System.Windows.Forms.Clipboard"
			local imageclass = dotNetclass "System.Drawing.image"
			local bytearr = convertclass.FromBase64String string
			local memstream = dotnetobject "System.IO.MemoryStream" bytearr
			local DecodedImg = ImageClass.fromstream memstream
			memstream.close()
			DecodedImg
		--	credits to Denis Trofimiv - http://forums.cgsociety.org/showpost.php?p=7708817&postcount=21
		function LoadMyLogoAsTitlebarIcon =
			d = (windows.getChildHWND 0 rol_miauuBatchLoadXRefScenes.title)[1]
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			bm = dotnetobject "System.Drawing.Bitmap" (String2Bmp logoIcon)
			ptr = bm.GetHicon()
			icon = (dotnetclass "System.Drawing.Icon").FromHandle (dotnetobject "IntPtr" ptr)
			windows.SendMessage d WM_SETICON ICON_SMALL icon.handle
        function AddColumns theLv columnsAr=
            if chkBox_showFullPath.state == false then
                w=(theLv.width)-6
                w=(theLv.width)+400
            for x in columnsAr do
                theLv.columns.add x w
        function PopulateListView theLv=
            rows=#()
            for x=1 to maxFiles.count do
                    mapName = (getFilenameFile maxFiles[x])
                    mapName = maxFiles[x]
                li = dotNetObject "System.Windows.Forms.ListViewItem" mapName
                append rows li
            theLv.items.addRange rows
        function InitListView theLv=
            theLv.clear()
			theLv.headerStyle = theLv.headerStyle.none
            theLv.view = (dotNetClass "system.windows.forms.view").details
            theLv.FullRowSelect = true
            theLv.MultiSelect = true
            theLv.checkBoxes = true
            theLv.backcolor = (dotNetClass "System.Drawing.Color").DimGray
            theLv.forecolor = (dotNetClass "System.Drawing.Color").lightGray
        function BatchListViewReIinit =
            InitListView lv_Batch
            AddColumns lv_Batch #("")
            PopulateListView lv_Batch
        function TurnBatchLVchkBoxOn =
            for i = 0 to lv_Batch.Items.count-1 do
                lv_Batch.Items.Item[i].checked = true
            lv_Batch.forecolor = disableForeColor
        function OpenFolders folderToOpen =
            local checkFolderName = substring folderToOpen 1 (folderToOpen.count-1)
            if (symbolicPaths.isPathName checkFolderName) then
                folderToOpen = symbolicPaths.getPathValue checkFolderName
            shellLaunch "explorer.exe" folderToOpen
        function GetFilesRecursive root pattern =
            dir_array = GetDirectories (root+"\*")
            for d in dir_array do
                join dir_array (GetDirectories (d+"*"))
            my_files = #()
            for f in dir_array do
                join my_files (getFiles (f + pattern))
            my_files
		function RemoveMissingDLLs =
			seek str 0
			cls = #()
				ln = readLine str
					clsName = tk[1]
					try
							append cls val
					catch
			c = 0
			foundMissing = #()
				cc = cls[j]
								try
									c += 1
									exit
								catch
						) -- end: for k
					) -- end: for i
				) -- end: if
			) -- end: for j
			if c > 0 then
				str = "Replaced "
					append str "\t"
					append str "\n"
				print "------------ removeMissingPlugins v0.1 ------------ "
				print str
				print foundMissing
    	on rol_miauuBatchLoadXRefScenes open do
    		try(LoadMyLogoAsTitlebarIcon())catch()
    		openFileRoll.title = "Select Files"
    		openFileRoll.Multiselect = true
    		openFileRoll.Filter = "MAX (*.max)|*.max"
    		openFileRoll.FilterIndex = 1
    		openFileRoll.RestoreDirectory = true
    	    AddColumns lv_Batch #("Files")
    	on lv_Batch mouseDown arg do
    	    --    delete selected max file from the listview
    	    if arg.button==arg.button.middle then
    	        if (hitNode = lv_Batch.GetItemAt arg.x arg.y) != undefined do
    	            deleteItem maxFiles (hitNode.index+1)
    	            BatchListViewReIinit()
    	    --    open folder of selected max file
    	    if arg.button==arg.button.right then
    	            f = (hitNode.index+1)
    	            folderToOpen = (getFilenamePath maxFiles[f])
    	on btn_getDir pressed do
    	    dir = getSavePath caption:"Select the directory" initialDir:"$scenes"
    	    if dir != undefined do
    	        maxFiles = #()
    	        --    get all max files
    	        maxFiles = getFiles (dir+"\*.max")
    	        --    check for subfolders
    	        subFiles = GetFilesRecursive dir "*.max"
    	        if subFiles.count != 0 then
    	            msg = "The selected folder have subfolders!\n"
    	            msg += "Do you want to include the files from the subfolders too?"
    	            if queryBox  msg title:"Sub-folders found" do
    	                join maxFiles subFiles
    			makeUniqueArray maxFiles
    	        TurnBatchLVchkBoxOn()
    	on btn_getFile pressed do
    		result = openFileRoll.showDialog()
    		result.ToString()
    		if (result.Equals result.OK) do
    			filePath = (openFileRoll.fileNames)
    			join maxFiles filePath
    	on btn_Clear pressed do
    	    maxFiles = #()
    	on chkBox_showFullPath changed state do
    		cbState = for i = 0 to lv_Batch.Items.count-1 collect lv_Batch.Items.Item[i].checked
    	    for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = cbState[i + 1]
    	on btn_all pressed do
    		for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = true
    	on btn_none pressed do
    		for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = false
    	on btn_invert pressed do
    		for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = not lv_Batch.Items.Item[i].checked
    	on bnt_saveAsPrevious pressed do
    		local xRefCnt = (lv_Batch.Items.count - 1)
    		setWaitCursor()
    		suspendEditing()
    		resetMaxFile #noPrompt
    		for i = 0 to xRefCnt where (lv_Batch.Items.Item[i].checked == true) do with redraw off
    			if (loadMaxFile maxFiles[i+1] useFileUnits:true quiet:true) do
					RemoveMissingDLLs()
    				filePath = getFilenamePath maxFiles[i+1]
					fileName = (getFilenameFile maxFiles[i+1])
					local ver = ddl_version.selected
					if chk_Copy.checked then (
						fileName = (getFilenameFile maxFiles[i+1]) += "_" + ver
    				newName = filePath + "\\" + fileName + ".max"
    				saveMaxFile newName saveAsVersion:(ver as integer) useNewFile:true quiet:true
    			pb_xRefprogress.value = 100.0 * i / xRefCnt
    			if curMaxVersion > 12 do
    				windows.processPostedMessages()
    		completeRedraw()
    		resumeEditing()
    		setArrowCursor()
    createdialog rol_miauuBatchLoadXRefScenes width:405
This is the Shawns's version. IF you want to use mine, then you have to edit the script.
Reply to miauu
Edward Snowden
Error on running script
Both 2012 and 2014 get the same error:
MAXScript Rollout Handler Exception
-- No ""="" function for (Global:getFilenameFile (RolloutLocal:maxFiles in rollout:rol_miauuBatchLoadXRefScenes[(%"+"() Local:i 1)]))
OK
It stop right there " fileName..."
Fixed. Try it:
-- Version:			1.10
-- Usage: RUN IT
-- Wishlist:
-- category:"miauu"
			memstream.close()
			DecodedImg
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			ptr = bm.GetHicon()
                w=(theLv.width)-6
                w=(theLv.width)+400
            rows=#()
                append rows li
            theLv.clear()
            my_files = #()
            my_files
			seek str 0
			cls = #()
				ln = readLine str
					clsName = tk[1]
					try
							append cls val
					catch
			c = 0
			foundMissing = #()
				cc = cls[j]
								try
									c += 1
									exit
								catch
						) -- end: for k
					) -- end: for i
				) -- end: if
			) -- end: for j
			if c > 0 then
				str = "Replaced "
					append str "\t"
					append str "\n"
				print str
				print foundMissing
				print "No missing plugins found"
    	        maxFiles = #()
    		result.ToString()
    	    maxFiles = #()
    		setWaitCursor()
    		suspendEditing()
					RemoveMissingDLLs()
						fileName = (getFilenameFile maxFiles[i+1]) + "_" + ver
    		completeRedraw()
    		resumeEditing()
    		setArrowCursor()
Reply to miauu
Edward Snowden
Work like a charm.
Work like a charm and no dialogue display in processing. Output *.max files are all good. Thanks man.
Hi, Shawn!
I have almost the same version as yours, but instead of ddl I use radiobuttons. :)
I hope the people will find your version useful and will use it.
Shawn Olson
I was going to write a function like this and luckily searched Google. Thanks Kostadin. Here is a modified version I made that creates a menu for the user to choose the version they need to save to and that the current version of Max is able to save to. Also, I added a checkbox so that the user can choose to overwrite the files instead of make copies (which is something I needed).
-- Version:			1.10
-- Usage: RUN IT
-- Wishlist:
category:"miauu"
			memstream.close()
			DecodedImg
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			ptr = bm.GetHicon()
                w=(theLv.width)-6
                w=(theLv.width)+400
            rows=#()
                append rows li
            theLv.clear()
            my_files = #()
            my_files
    	        maxFiles = #()
    		result.ToString()
    	    maxFiles = #()
    		setWaitCursor()
    		suspendEditing()
    		completeRedraw()
    		resumeEditing()
    		setArrowCursor()
I don't have time to modify the UI.
Load the files that you want and press the Save As Previous button. All files will be saved in folder where the original files are with prefix _2013.
-- Last Updated:	14-06-2014
-- Version:			1.00
-- Discription: Batch save selected MAX files as copies for Max 2013
-- Usage: RUN IT
-- Wishlist:
category:"miauu"
        dotNetControl lv_Batch "system.windows.forms.listView" height:200 width:273 pos:[10,10]
		button btn_getDir "Get Directory" width:108 pos:[290,10] tooltip:"Select all .max files in the given folder and/or its sub-folders"
        button btn_getFile "Get file(s)" width:108 pos:[290,35] tooltip:"Select one or multiple files in given folder"
        button btn_Clear "Clear" width:108 pos:[290,60]
		button bnt_saveAsPrevious "Save as previous" width:275 height:30 pos:[10,235]
		hyperLink http_miauu "miauu's MaxScripts" address:"http://miauumaxscript.blogspot.com/" pos:[300,270] color:(color 7 231 251)
		progressBar pb_xRefprogress value:0 color:green width:275 pos:[10,270]
		--	Credist to Peter Addington - http://lonerobot.net/?p=314
			memstream.close()
			DecodedImg
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			ptr = bm.GetHicon()
                w=(theLv.width)-6
                w=(theLv.width)+400
            rows=#()
                append rows li
            theLv.clear()
            my_files = #()
            my_files
                maxFiles = #()
			result.ToString()
            maxFiles = #()
        on lv_Batch MouseDown arg do
			setWaitCursor()
			suspendEditing()
					fileName = (getFilenameFile maxFiles[i+1]) + "_2013"
					saveMaxFile newName saveAsVersion:2013 useNewFile:true quiet:true
			completeRedraw()
			resumeEditing()
			setArrowCursor()
