Batch import .jt and save as .max
By Steffen · 2017-06-20
Hi guys,
maybe anyone could help me out with a simple script?
It should do batch operations:
Look into each subfolder of a mainfolder for a file with always the same name xyz.jt, import it in my 3ds max 2016 and save it in the same spot with the same name as the original .jt file, just as .max.
I came across a similar one, but more than 10 years old:
http://www.scriptspot.com/3ds-max/scripts/iges-batch-importer
I guess it is doing more or less what I want, just to .iges instead of .jt. Since I have no idea how to modify it to suit my needs, maybe somebody can show me how to do it?
Any help is very much appreciated!!!
Thanks alot in advance!!
I don't know if this will works, because I don't have jt file, but try it:
-- IgesBatchImporter.ms
-- Copyright ©2000, Discreet
-- By Simon Feltman, simon@asylum-soft.com
global igesInputPath = "C:\\3dsmax\\jt\\"
global igesOutputLog = "C:\\3dsmax\\jt\\igeslog.csv"
global igesRecursive = true
global igesRandomize = true
global igesSaveMaxFile = true
global igesCountSurfs  = true
rollout igesBatchRollout "jt Batch Importer"
	Group "Input Path"
		EditText ed_path width:136 height:20 align:#left offset:[-6,0] text:igesInputPath
		Button  btn_path "..." width:16 height:17 \
			pos:[ed_path.pos.x+136, ed_path.pos.y] \
			tooltip:"Browse input path..."
	Group "Output Log"
		EditText ed_log width:136 height:20 align:#left offset:[-6,0] text:igesOutputLog
		Button  btn_log "..." width:16 height:17 \
			pos:[ed_log.pos.x+136, ed_log.pos.y] \
			tooltip:"Save log file..."
	Group "Options"
		CheckBox  chk_recursive	"Recurse sub-directories" align:#left offset:[-1,0] checked:igesRecursive
		CheckBox  chk_randomize "Randomize import order" align:#left offset:[-1,0]  checked:igesRandomize
		CheckBox  chk_saveMaxFile "Save MAX file" align:#left offset:[-1,0]         checked:igesSaveMaxFile
		CheckBox  chk_countSurfs "Count Surfaces" align:#left offset:[-1,0]         checked:igesCountSurfs
	Button btn_doBatchImport "Do Batch Import" width:164
	function LogOut text =
		local ostream = undefined
		if ed_log.text != undefined and ed_log.text != "" then
			ostream = OpenFile ed_log.text mode:"a"
		if ostream != undefined then
			format text to:ostream
			close ostream
		else format text
	function DoImport inpath =
		local exts = #("*.jt", "*.jt")
		local files = #()
		if inpath[inpath.count] != "\\" then
			inpath += "\\"
		format "%\n" inpath
		-- Get a listing of files into array 'files'
		for e in exts do
			Join files (GetFiles(inpath + e))
		-- Randomize the file listing if specified
		if chk_randomize.checked then
			for i = 1 to files.count do
				local j = Random 1 files.count
				local tmpstr = files[i]
				files[i] = files[j]
				files[j] = tmpstr
		-- Go through each file and import it
		for f in files do
			local startTime = TimeStamp()
			LogOut ("\"" + f + "\",")
			try
				ImportFile f #noprompt
				RedrawViews()
				LogOut "Succeeded,"
				if chk_saveMaxFile.checked then
					f = (GetFilenamePath f) + (GetFilenameFile f) + ".max"
					SaveMaxFile f
					LogOut "Succeeded,"
				else LogOut "N/A,"
				-- count surfaces
				local numSurfs = "N/A"
				if chk_countSurfs.checked then
					numSurfs = 0
					for obj in objects do
						if (classOf obj) == NURBSSurf then
							numSurfs += obj.surfaces.count
						else if (classOf obj) == SplineShape then
							numSurfs += obj.numsplines
						else if (classOf obj) == NURBSCurveShape then
							numSurfs += obj.curves.count
				LogOut ((numSurfs as string) + ",")
				local stime = (TimeStamp()-startTime) / 1000.0
				LogOut ((stime as string) + "\n")
				ResetMaxFile #noPrompt
			catch
				LogOut "Failed\n"
		if chk_recursive.checked then
			for d in GetDirectories (inpath + "*") do
				if not (DoImport d) then
					return false
		return true
	on igesBatchRollout open do
		try   ( FileIn ((GetDir #plugcfg) + "\\jtBatchImporter.txt") )
		catch ( Format "jtBatchImporter.txt does not exist, will be created.\n" )
		ed_path.text = igesInputPath
		ed_log.text = igesOutputLog
		chk_recursive.checked = igesRecursive
		chk_randomize.checked = igesRandomize
		chk_saveMaxFile.checked = igesSaveMaxFile
		chk_countSurfs.checked  = igesCountSurfs
	on igesBatchRollout close do
		ostream = CreateFile ((GetDir #plugcfg) + "\\jtBatchImporter.txt")
		Format "igesInputPath = \"%\"\n" ed_path.text to:ostream
		Format "igesOutputLog = \"%\"\n" ed_log.text to:ostream
		Format "igesRecursive = %\n" chk_recursive.checked to:ostream
		Format "igesRandomize = %\n" chk_randomize.checked to:ostream
		Format "igesSaveMaxFile = %\n" chk_saveMaxFile.checked to:ostream
		Format "igesCountSurfs  = %\n" chk_countSurfs.checked to:ostream
		Close ostream
	on btn_path pressed do
		local path = GetSavePath caption:"Choose jt Import Directory"
		if path != undefined then
			ed_path.text = path
	on btn_log pressed do
		local logpath = GetSaveFileName filename:ed_log.text caption:"Choose Log File"      \
			types:"Excel Text Files (*.csv)|*.csv|Text Files (*.txt)|*.txt|Log Files (*.log)|*.log|All Files (*.*)|*.*|"
		if logpath != undefined then
			ed_log.text = logpath
	on btn_doBatchImport pressed do
			local ostream = CreateFile ed_log.text
			Close ostream
		LogOut "File Name,Import Status,Save Status,Surface Count,Time Elapsed\n\n"
		DoImport ed_path.text
-- MacroScript IgesBatchImporter category:"Tools" tooltip:"jt Batch Importer"
 	igesBatchFloater =  NewRolloutFloater "jt Batch Importer" 200 294
	AddRollout igesBatchRollout igesBatchFloater
ALso, you can try this script, that I wrote to batch save OBJ as MAX file, but now it have to works with jt files:
-- Created: 		23-06-2015
-- Last Updated:	17-11-2015
-- Version:			1.10
-- Author :  Kostadin Kotev / miau_u@yahoo.com / http://miauumaxscript.blogspot.com/
-- Version:  3ds max 2010 and up
-- Discription: Batch save selected JT files as .max files.
-- Usage: RUN IT
-- Wishlist:
-- MODIFY THIS AT YOUR OWN RISK
macroscript miauuBatchSaveObjAsMax
category:"miauu"
tooltip:"Batch Save JT As Max"
buttonText:"Batch Save JT As Max"
	global rol_miauuBatchSaveObjToMax
    try(destroyDialog rol_miauuBatchSaveObjToMax)catch()
    rollout rol_miauuBatchSaveObjToMax "miauu's Batch Save JT As Max"
		local ConvertClass = dotnetclass "system.convert"
		local ImageClass = dotnetclass "system.drawing.image"
		local logoIcon = "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"
		local curMaxVersion = ((maxVersion())[1] / 1000)
		local openFileRoll = dotNetObject "System.Windows.Forms.OpenFileDialog"
        local disableForeColor = (dotNetClass "System.Drawing.Color").white
        local maxFiles = #()
        dotNetControl lv_Batch "system.windows.forms.listView" height:200 width:273 pos:[10,10]
		button btn_getDir "Get Directory" width:108 pos:[290,10] tooltip:"Select all .max files in the given folder and/or its sub-folders"
        button btn_getFile "Get file(s)" width:108 pos:[290,35] tooltip:"Select one or multiple files in given folder"
        button btn_Clear "Clear" width:108 pos:[290,60]
		radiobuttons rb_saveAs "Save As:" pos:[290,85]  labels:#("2010", "2011", "2012", "2013", "2014", "2015", "2016") default:1 columns:1
		checkbox chkBox_showFullPath "Show Full Path" pos:[10,215]
		label lbl_select "Select:" pos:[120,215]
		button btn_all "All" pos:[157,214] width:40 height:18
		button btn_none "None" pos:[200,214] width:40 height:18
        button btn_invert "Invert"	 pos:[243,214]	width:40 height:18
		button bnt_saveAsPrevious "Save JT As Max" width:275 height:30 pos:[10,235]
		hyperLink http_miauu "miauu's MaxScripts" address:"http://miauumaxscript.blogspot.com/" pos:[300,270] color:(color 7 231 251)
		progressBar pb_xRefprogress value:0 color:green width:275 pos:[10,270]
		--	Credist to Peter Addington - http://lonerobot.net/?p=314
		function String2Bmp string =
			local clipboardClass = dotNetClass "System.Windows.Forms.Clipboard"
			local imageclass = dotNetclass "System.Drawing.image"
			local bytearr = convertclass.FromBase64String string
			local memstream = dotnetobject "System.IO.MemoryStream" bytearr
			local DecodedImg = ImageClass.fromstream memstream
			memstream.close()
			DecodedImg
		--	credits to Denis Trofimiv - http://forums.cgsociety.org/showpost.php?p=7708817&postcount=21
		function LoadMyLogoAsTitlebarIcon =
			d = (windows.getChildHWND 0 rol_miauuBatchSaveObjToMax.title)[1]
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			bm = dotnetobject "System.Drawing.Bitmap" (String2Bmp logoIcon)
			ptr = bm.GetHicon()
			icon = (dotnetclass "System.Drawing.Icon").FromHandle (dotnetobject "IntPtr" ptr)
			windows.SendMessage d WM_SETICON ICON_SMALL icon.handle
        function AddColumns theLv columnsAr=
            if chkBox_showFullPath.state == false then
                w=(theLv.width)-6
                w=(theLv.width)+400
            for x in columnsAr do
                theLv.columns.add x w
        function PopulateListView theLv=
            rows=#()
            for x=1 to maxFiles.count do
                    mapName = (getFilenameFile maxFiles[x])
                    mapName = maxFiles[x]
                li = dotNetObject "System.Windows.Forms.ListViewItem" mapName
                append rows li
            theLv.items.addRange rows
        function InitListView theLv=
            theLv.clear()
			theLv.headerStyle = theLv.headerStyle.none
            theLv.view = (dotNetClass "system.windows.forms.view").details
            theLv.FullRowSelect = true
            theLv.MultiSelect = true
            theLv.checkBoxes = true
            theLv.backcolor = (dotNetClass "System.Drawing.Color").DimGray
            theLv.forecolor = (dotNetClass "System.Drawing.Color").lightGray
        function BatchListViewReIinit =
            InitListView lv_Batch
            AddColumns lv_Batch #("")
            PopulateListView lv_Batch
        function TurnBatchLVchkBoxOn =
            for i = 0 to lv_Batch.Items.count-1 do
                lv_Batch.Items.Item[i].checked = true
            lv_Batch.forecolor = disableForeColor
        function OpenFolders folderToOpen =
            local checkFolderName = substring folderToOpen 1 (folderToOpen.count-1)
            if (symbolicPaths.isPathName checkFolderName) then
                folderToOpen = symbolicPaths.getPathValue checkFolderName
            shellLaunch "explorer.exe" folderToOpen
        function GetFilesRecursive root pattern =
            dir_array = GetDirectories (root+"\*")
            for d in dir_array do
                join dir_array (GetDirectories (d+"*"))
            my_files = #()
            for f in dir_array do
                join my_files (getFiles (f + pattern))
            my_files
        on btn_getDir pressed do
            dir = getSavePath caption:"Select the directory" initialDir:"$scenes"
            if dir != undefined do
                maxFiles = #()
                --    get all max files
                maxFiles = getFiles (dir+"\*.jt")
                --    check for subfolders
                subFiles = GetFilesRecursive dir "*.jt"
                if subFiles.count != 0 then
                    msg = "The selected folder have subfolders!\n"
                    msg += "Do you want to include the files from the subfolders too?"
                    if queryBox  msg title:"Sub-folders found" do
                        join maxFiles subFiles
				makeUniqueArray maxFiles
                TurnBatchLVchkBoxOn()
        on btn_getFile pressed do
			result = openFileRoll.showDialog()
			result.ToString()
			if (result.Equals result.OK) do
				filePath = (openFileRoll.fileNames)
				join maxFiles filePath
                BatchListViewReIinit()
		on btn_all pressed do
			for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = true
		on btn_none pressed do
			for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = false
		on btn_invert pressed do
			for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = not lv_Batch.Items.Item[i].checked
        on btn_Clear pressed do
            maxFiles = #()
        on lv_Batch MouseDown arg do
            --    delete selected max file from the listview
            if arg.button==arg.button.middle then
                if (hitNode = lv_Batch.GetItemAt arg.x arg.y) != undefined do
                    deleteItem maxFiles (hitNode.index+1)
            --    open folder of selected max file
            if arg.button==arg.button.right then
                    f = (hitNode.index+1)
                    folderToOpen = (getFilenamePath maxFiles[f])
        on chkBox_showFullPath changed state do
			cbState = for i = 0 to lv_Batch.Items.count-1 collect lv_Batch.Items.Item[i].checked
            for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = cbState[i + 1]
		on bnt_saveAsPrevious pressed do
			local xRefCnt = (lv_Batch.Items.count - 1)
			local versionIndex = case rb_saveAs.state of
				1: 2010
				2: 2011
				3: 2012
				4: 2013
				5: 2014
				6: 2015
				7: 2016
			setWaitCursor()
			suspendEditing()
			resetMaxFile #noPrompt
			for i = 0 to xRefCnt where (lv_Batch.Items.Item[i].checked == true) do with redraw off
				importFile maxFiles[i+1] #noPrompt
				filePath = getFilenamePath maxFiles[i+1]
				fileName = (getFilenameFile maxFiles[i+1]) + "_" + (versionIndex as string)
				newName = filePath + "\\" + fileName + ".max"
				if versionIndex == 2016 then
					saveMaxFile newName useNewFile:true quiet:true
					saveMaxFile newName saveAsVersion:versionIndex useNewFile:true quiet:true
				pb_xRefprogress.value = 100.0 * i / xRefCnt
				if curMaxVersion > 12 do
					windows.processPostedMessages()
			completeRedraw()
			resumeEditing()
			setArrowCursor()
        on rol_miauuBatchSaveObjToMax open do
			try(LoadMyLogoAsTitlebarIcon())catch()
			openFileRoll.title = "Select Files"
			openFileRoll.Multiselect = true
			openFileRoll.Filter = "jt (*.jt)|*.jt"
			openFileRoll.FilterIndex = 1
			openFileRoll.RestoreDirectory = true
            AddColumns lv_Batch #("Files")
    createdialog rol_miauuBatchSaveObjToMax width:405
