Auto save
By Adam · 2012-06-11
Could someone please edit this so that while I am editing boxes, it will autosave to the text file when changes are made.
txtFile = "C:\Users\YourName\Desktop\boxInfo.txt"
if doesFileExist txtFile then
theFile = openFile txtFile mode:"at"
theFile = createFile txtFile
fn print_data_to_file obj=
format "\n\n%\n%\n%\n%\n%\n%\n%\n%\n%\n%\n" obj.name obj.length obj.width obj.height obj.position.x obj.position.y obj.position.z \
(obj.rotation as EulerAngles).x (obj.rotation as EulerAngles).y (obj.rotation as EulerAngles).z to:theFile
)--end fn
for theBox in $Box* do print_data_to_file theBox
close theFile
This is your script
It is better to use *.ini for this then *.txt
*.ini will be created in directory where is the this script placed.
Run script, press "Record" checkbutton and change some paremeters on the your boxes. When you change selections the props are saved automatically.
global aprRoll
if aprRoll != undefined do try (destroyDialog aprRoll) catch()
rollout aprRoll " AutoPropsRecorder"
local recorder = false
checkbutton rec "R E C O R D" width:120 highlightcolor:[150,10,10]
fn saveINISettings =
local iniFile = getFilenamePath (getSourceFileName()) + "boxInfo.ini"
for obj in $Box* as array do
local sectionName = obj.name, p = obj.pos, r = quatToEuler2 obj.transform.rotation
local propsNames = #("Length", "Width", "Height", "PosX", "PosY", "PosZ", "RotX", "RotY", "RotZ")
local propsValues = #(obj.length as string, obj.width as string, obj.height as string, \
p.x as string, p.y as string, p.z as string, r.x as string, r.y as string, r.z as string)
for i in 1 to propsNames.count do (setINISetting iniFile sectionName propsNames[i] propsValues[i])
on rec changed state do
if state then
callbacks.removeScripts #selectionSetChanged id:#record
if ($Box* as array).count == 0 then (messagebox "Create some boxes" title:"RecorderWarning" beep:false ; rec.checked = false)
else ( callbacks.addscript #selectionSetChanged "aprRoll.saveINISettings()" id:#record ; recorder = true)
else (callbacks.removeScripts #selectionSetChanged id:#record ; recorder = false)
on aprRoll close do (if record == true do (callbacks.removeScripts #selectionSetChanged id:#record) ; gc())
createdialog aprRoll 130 30 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
