Auto Hierarchy - Control Objects
By AndreShaw · 2011-03-29
In the max file attached I have provided 2 bone chains. The one labeled "What I Want" is what I would like my script to do once I run it. The other bone chain is for you to run the script on. So far my script will create a point helper at the exact pivot of each object you have selected, but not link them, as in the example "What I want". The end result being, a point helper created at each bones pivot, and linking them through the hierarchy in correlation to the hierarchy of the bone chain.
function createPoint =
for Cntrl =1 to selection.count do
Cntrl = selection[Cntrl]
Control_IK=point wirecolor: red
Control_IK.size = Cntrl.width*5
Control_IK.cross = true
Control_IK.transform = Cntrl.transform
createPoint()
JokerMartini
Nice Garp, that works out well. I actually never used the showLinks property. I always forget about that being in max.
Great stuff.
Garp
Something like this:
Select the root of your hierarchy and run this:
fn setCtrlPts theObj thePt:undefined =
  local pt = point transform:theObj.transform \
             name:("ctrl_" + theObj.name) \
             wireColor:green \
             showLinks:true
  pt.parent = thePt
  for obj in theObj.children do
    setCtrlPts obj thePt:pt
setCtrlPts selection[1]
Customize the points to your needs :D
