Is there a way to apply a material from within a SimpleMeshMod without triggering and recursive loop of the object changing?
When the Enable button is pressed, i want the material applied, otherwise I'm planning on then restoring the original material. But i can't even get the temp material applied without it crashing. Do i need to store the material in a local variable and not the param block?
clearlistener()
plugin simpleMeshMod myMaterialModifier
classid:#(0x491fdf76, 0x7493038e)
local tempMaterial = MultiSubMaterial()
parameters MainParams rollout:MainRollout
isModifierActive type:#boolean ui:uiIsModifierActive
previewMaterial type:#material
rollout MainRollout "Main" rolledUp:false
checkbutton uiIsModifierActive "Enable" width:160 align:#center
/* Actions */
on create do
previewMaterial = MultiSubMaterial()
on modifyMesh do
if isModifierActive then
/* Material */
format "Preview Material > %\n" previewMaterial
format "Node Material > %\n" owningNode.material
format "== %\n" (owningNode.material == previewMaterial)
if owningNode.material != previewMaterial do
/* causes endless update loop */
-- owningNode.material = previewMaterial
