Apply Turbosmooth modifier to selection
By Simon · 2016-09-01
New forum topics are on pause. Signed-in members can reply to existing topics. Contact ScriptSpot if you need help.
Hey guys,
I`m looking for a script that does the following:
When you run the script on your selection of objects, check if there are any turbosmooth modifiers already applied. If there are any applied, do nothing.
If there aren`t any applied, apply two turbosmooth modifiers. The first one with two iterations and seperate by smoothing groups turned on, the second one with one iteration and seperate by smoothing groups turned off.
It would be awesome if someone could help with this.
Thank you very much!
fajar
try this ....the different from miauu is , it will not add turbosmooth modifier to instanced nodes
fn collectTrueObject sel:(selection as array) nodes:#() =
	local allObj = #()
	local inst=InstanceMgr.GetInstances
	for i in sel where  (findItem allObj i ==0 )do
		inst i &theNodes
		join allObj theNodes
		append nodes i
	nodes
fn myTurboSmooth =
	ts =TurboSmooth iterations:2 sepBySmGroups:true
	ts
mapped fn addModToSelection nodes =
	local found=false
	for i in nodes.Modifiers where (isKindOf i TurboSmooth) do found =true
	if found==false do addmodifier nodes (myTurboSmooth())
max create mode
with redraw off
objs=collectTrueObject()
addModToSelection objs
free objs
-- please select some nodes first
Hope this'll work
( function
	function AddTurboSmootModifier obj =
		tsMod = TurboSmooth()
		tsMod.iterations = 2
		tsMod.sepBySmGroups = true
		addModifier obj tsMod
		tsMod.iterations = 1
		tsMod.sepBySmGroups = false
	if selection.count != 0 do
		selObjsArr = selection as array
		for o in selObjsArr do
			if o.modifiers.count != 0 then
				tsModExist = false
				stopLoop = false
				for m = 1 to o.modifiers.count while stopLoop == false do
					if classOf o.modifiers[m] == TurboSmooth do
						stopLoop = true
						tsModExist = true
				if tsModExist == false do
