Align Verts - With Constraints
By JokerMartini · 2010-07-05
Does anyone know of any script that aligns verts but constrains the 2 end verts of the selection. See image for better explanation.
Select a column of verts and have the first and last verts in the selection remain unmoved,(highlighted green in the image) but have the other verts (highlighted yellow in the image) align on the x,y or z, axis.
JokerMartini
Graph
afaik, no but you can easily write one if you know wich one the "outer verts" are, based on what rules they are supposed to be first and last in 3d space
like so:
	fn pointLineProj pA pB pC = --gets the closest point on a line to a point in space
		local vAB=pB-pA ; local vAC=pC-pA ; local d=dot (normalize vAB) (normalize vAC) ;
		return (pA+(vAB*(d*(length vAC/length vAB)))) ;
	local firstVert = 3
	local lastVert = 23
	local vertsToAlign = #(18, 13, 8)
	local obj = $Plane013
	local vert1Pos = polyOp.getVert obj firstVert node:obj
	local vert2Pos = polyOp.getVert obj lastVert node:obj
	for v in vertsToAlign do
		local vPos = polyOp.getVert obj v node:obj
		local tPos = pointLineProj vert1Pos vert2Pos vPos
		polyOp.setVert obj #{v} tPos node:obj
