Align Slice Modifier gizmo to 3points
By diferent · 2015-06-22
Hello everyone,
I have a simple problem. I need quickly and easily tool to align slice gizmo by three points. Is there anyone who help me please?
Thanks so much 😆
Mira
situation 1)
situation 2)
Comments (9)
alnoman
in perspective viewport move and rotate the as you wish and use quick slice tool in editpoly.
	curO = selection[1]
	sliceMod = curO.modifiers[1]
	--	get the three points and builda matrix
	pos01 = polyop.getVert curO 8
	pos02 = polyop.getVert curO 5
	pos03 = polyop.getVert curO 2
	local vect1 = normalize (pos02 - pos01)
	local vect2 = normalize (pos03 - pos02)
	local vect3 = normalize (cross vect2 vect1)
	vect2 = cross vect3 vect1
    objTM = curO.objectTransform
    modTM = getModContextTM curO sliceMod
    -- set slice plane position at world coordinates f one of the points
	pos = ((pos01 + pos02 + pos03) / 3) * modTM * (inverse objTM)
	--	build temp matrix
	tempMatrix = ((matrix3 vect1 vect2 vect3 pos ))
	--	align the slice plane
	curO.slice.slice_plane.transform = tempMatrix
Reply to diferent
Try this:
	on execute do  with undo off
		curO = selection[1]
		if curO.modifiers.count != 0 and classOf (sliceMod = curO.modifiers[1]) == SliceModifier do
			local pos01 = undefined
			local pos02 = undefined
			local pos03 = undefined
			local curSnapMode = snapMode.active
			local curSnapType = snapMode.type
			snapMode.active = true
			snapMode.type = #3D
			pos01 = pickPoint snap:#3d
			if classof pos01 == point3 do
				pos02 = pickPoint snap:#3d rubberBand:pos01
			if classof pos02 == point3 do
				pos03 = pickPoint snap:#3d rubberBand:pos02
			snapMode.active = curSnapMode
			try(snapMode.type = curSnapType)catch()
			if classof pos01 == point3 and classof pos02 == point3 and classof pos03 == point3 do
Run it and pick 3 points in the scene. The SNAP will be turned On automatically.
		curO = selection[1]
		sliceMod = SliceModifier ()
		addModifier curO  sliceMod
		snapMode.type = #3D
Haider Alghifary
It is a great script request though. It makes sense, wanting to align the gizmo in a certain way. It could as well being the UV gizmo that you want to align to those three verts..
vusta
not tool but suggestion...
Assumming your object is far more complexed than a simple cube,
what about make 3 cuts, ie. cut from vert 1 to 2 to 3, then select the 'other' vert at the tip, grow until desired, then delete...?
