How do I adjust the ctrlKey if/then statement so when users hold ctrlKey the object is then aligned vertically?
plugin simpleObject PlanePlus
category:"Special Primitives"
classID:#(0x6166ee57, 0x2653467f)
parameters main rollout:rltParams
height type:#worldUnits ui:uiHeight default:0.0
width type:#worldUnits ui:uiWidth default:0.0
mapCoords type:#boolean ui:uiMapCoords default:true
realWorldMapSize type:#boolean ui:uiRealWorldMapSize default:false
rollout rltParams "Parameters"
spinner uiWidth "Width:" range:[0, 1e9, 0.0] type:#worldUnits
spinner uiHeight "Length:" range:[0, 1e9, 0.0] type:#worldUnits
checkBox uiMapCoords "Generate Mapping Coords" checked:true offset:[0, 9]
checkBox uiRealWorldMapSize "Real-World Map Size" checked:false
on hasUVW do map_coords
on setGenUVW bool do map_coords = bool
fn genMesh =
local vertCount = 4
/*Set Vertices*/
local verticesArr = #([0, 0, 0],[width, 0, 0],[width, height, 0],[0, height, 0])
/*Set Faces*/
local facesArr = #([1,2,3],[3, 4, 1])
/*Set Mesh*/
setMesh mesh verts:verticesArr faces:facesArr
--setMesh mesh verts:verticesArr faces:facesArr materialIDs:#(1,1)-- tverts: --alternate
setEdgeVis mesh 1 3 false
setEdgeVis mesh 2 3 false
/*Set Texture Coordinates*/
if mapCoords do (
setNumTVerts mesh vertCount
if realWorldMapSize then
for i = 1 to vertCount do
setTVert mesh i verticesArr[i]
local maxLength = amax #(height,width)
setTVert mesh i (verticesArr[i] / maxLength + [0, 0, 0])
buildTVFaces mesh false
for i = 1 to facesArr.count do
setTVFace mesh i facesArr[i]
on buildMesh do (genMesh())
tool create
local first_pos
on mousePoint click do (
case click of (
1: (coordSys grid (nodeTM.translation = first_pos = gridPoint))
2: #stop
on mouseMove click do (
case click of (
2: (
height = length (gridDist * [0, 1, 0])
width = length (gridDist * [1, 0, 0])
if shiftKey do (height = width = length (gridDist * [1, 1, 0]))
if ctrlKey do coordSys grid
nodeTM = rotateXMatrix gridAngle.X
fixed!
nodeTM = rotateXMatrix 90.0
