i'm Trying to Add Doubleclick Event to flowlayoutpanel buttons but its not Working!, How Can i Fix That?
i Tried Both Ways (DoubleClick) and (MouseDoubleClick)
THANKS in ADVANCED
if test_roll != undefined then try(destroyDialog test_roll)catch()
rollout test_roll "TEST"
dotNetControl 'flp_test' "flowlayoutpanel" pos:[10,10] width:170 height:90
fn add_btns =
for i = 1 to 6 do (
btn = dotnetobject "Button"
btn.flatstyle = (dotNetclass "System.Windows.Forms.FlatStyle").flat
btn.backcolor = (dotnetclass "System.Drawing.Color").FromArgb 40 40 40
btn.forecolor = (dotnetclass "system.drawing.color").FromArgb 230 230 230
btn.FlatAppearance.BorderSize = 0
btn.text = i as string
btn.tag = dotNetObject "System.String" "Its Working !"
fn btn_DoubleClick = (print "Its Working !")
fn btn_MouseDoubleClick btn arg = (
if arg.button == arg.button.left do (print btn.tag)
dotNet.addEventHandler btn "MouseDoubleClick" btn_MouseDoubleClick
dotNet.addEventHandler btn "DoubleClick" btn_DoubleClick
dotNet.setLifeTimeControl btn #dotNet
test_roll.flp_test.Controls.Add(btn)
on test_roll open do (
flp_test.backcolor = (dotnetclass "System.Drawing.Color").FromArgb 55 55 55
flp_test.controls.clear()
add_btns()
createdialog test_roll 190 110
Thank you very much jahman , best regards.
As you exit add_btns function both btn_DoubleClick and btn_MouseDoubleClick cease to exist because of garbage collector.
Check dotNet.setLifetimeControl in reference
.upd my bad.. I see that you actually use it already
here's a workaround
