a way to only select objects that intersect in one spline.
By dussla · 2019-08-17
hi
sorry for asking help always~
that is my limit
i wonder a way to only select objects that intersect in one spline.
i seen many www site
but i did not found good code
pls help ~
Thanks in advance
Panteleev Sergey
it isn't an easy task especially if spline contains holes
Reply to dussla
Panteleev Sergey
this will select all objects which bounding boxes are intersecting with the rectangle's bounding box
  rect = selection[1]
  select (for obj in objects where intersects obj rect collect obj)
  deselect rect
if your rectangle is rotated about Z axis then it requires a bit trickier solution
