A script that uses some of the extra text outputs from Pix4d to create a camera in Max would be awesome!
By ziltoid · 2017-11-02
Hi. I'm using Pix4d a lot for work, but there is no option to export the calculated cameras as .fbx cameras or similar. Photoscan has this option, and pix4d exports a bunch of extra files with all the information about the camera positions etc, so it should be possible.
I don't have it on this machine, but if anyone wants to give it a go, I can upload some images and the folder with extra files when I'm back at work.
A description of all the different parameters that are exported can be found here:
https://support.pix4d.com/hc/en-us/articles/202977149#label1&gsc.tab=0
It would make it much easier to mix images from a drone and 3d renders, with the fbx export that photoscan has, the images line up perfectly with the mesh right away
thank you.
