3ds max startup material
By mohdmistry · 2011-06-12
hey there
is there any way that will enable u to have default material allready applied to any geometry created ?
cuz i wanna have black wireframe, and grey material polygon when im modeling.
here is...
fn cbfnNodeCreated = (
	theNode = callbacks.notificationParam()
	if theNode.category == #Standard_Primitives do (
		theNode.material = standard()
		theNode.wirecolor = black
callbacks.removeScripts #sceneNodeAdded id:#customSettings
callbacks.addScript #sceneNodeAdded "cbfnNodeCreated()" id:#customSettings
Reply to Panayot Karabakalov
mohdmistry
great thanks for "Lord Anubis"
u are a genius, and not a normal one, but a f*n genius.
i,ve been lookin for something like this for long.
Some scripted objects are added in Standard Primitives category but I can't apply startup material to them. maxscript shows category as #Standard Primitives instead of #Standard_Primitives
How can I fix that?
Reply to mwaif
If theses new plugs are not encripted you can change category by yourself to #Standard_Primitives or on the other hand change Anucis code (this line)
if theNode.category == "Standard Primitives" as name do (/*rest of the code*/)
I'm afraid some of them are encrypted and changing the line in script to: theNode.category == "Standard Primitives" does not work :(
