Hello
I am a user of 3ds max 2016 64bit (Win 7)
I do import Inventor files (aim, ipt) into 3ds max.
My problem is that 3ds max imports inventor´s assembly as a group.
For example I have a scene in 3ds max which looks like: one group (called Assembly) that contains three objects (meshes)
e.g.
Assembly
- Object01
- Object02
- Assembly_Pivot
So, I would be very grateful if someone could help me make a script that would do the following:
Find if there is a group in the scene, if so open it, find the object inside this group with the same name (but with postfix _Pivot), and replace this group with this object (as a new parent).
So it means Assembly will be deleted and replaced with Assembly_Pivot, which becomes a new parent of other objects which were in Assembly..
The pivot position of Assembly_Pivot cannot be changed (or position of Assembly_Pivot), meaning, it cannot inherit the pivot position of Assembly.
So new scene after the script will look like this:
Assembly_Pivot
- Object01
- Object02
Thanks a lot in advance for the help.
