3D Max FBX AutoFill Script
By Toby · 2016-08-08
Hi, is there anyone who could write a script that allows a person to export a model/object to FBX but the FBX options are automatically filled in so that the FBX panel is bypassed therefore the FBX panel does not open.
Basically I am looking for an easier way to export a model/object from 3D Max to Lumion using the FBX format. But I get fed up turning options on/off ect, it would be nice to be able to edit a script file (like an xml file so to speak) where I can set each script up to work using different export settings.
Basically have separate script files that export using FBX using options I choose to include/exclude.
I hope that make some form of sense and if you manage to help then thank you for taking the time to do so...
BGD :)
Toby
Thanks Fajar!
Much appreciated Fajar, anything to help would be great! :-)
fajar
its so simple tho if you want to browse a little in "FBX export" in maxscript helpfile ...tho there are already such script exist in this site and if you want to google it you can find many in cgtalk forum later....I'll try to post it later after I got my PC back on my home.
