I need to script ASAP. I have a 3d max file with MassFX physics of a bowling ball game which is setup, it's like http://www.turbosquid.com/3d-models/3ds-skee-ball-skee-ball/362629 (with the others alley's removed). The file is at https://www.dropbox.com/s/5hy0ycu55vcdvu8/skee_ball_final_phys2.zip?v=0s…
I need a max script that will throw the ball with a range of 100 different starting position and velocities and then output the screen x, screen y position, and distance from the view camera and if the middle of the ball is hidden behind one of scoring tubes. I will then use this data to replay a ball throw within a Javascript game.
So the script needs to
- Set the initial bass position and velocity
- Start the MassFX simulation
- At each frame record the ball screen position , world position, rotation & distance from the camera & if the centre of the ball is behind one of the tubes - output to a JSON format.
- Check at the end if that throw was a scoring one.
- Restart with the next starting position and velocity.
Let me know if you can do this in the next day or so and how much
Thanks James
james@joyplay.com
