Good evening wizards of Xref-land!
I'm working on a script for updating XrefObjs in scenes with identical numbers of objects and running into some trouble...
Before executing the script "C:\\test\\srcScn1.max" exists in the local scene as an Xref record.
These two scenes ("srcScn1" and "SrcScn2") are currently identical in content, I'm just trying to flip the switch to change the 'Xref Object' 'File Name' field before running the update script it's path is "C:\\test\\srcScn1.max"
xr = objXRefMgr
Record = xr.GetRecord 1
a = #()
x = Record.GetItems #XRefAllType a
for i = 1 to x do
XRefItem = Record.GetItem i #XRefObjectType
if XRefObjectType = true
then
xr.SetXRefItemSrcFile XRefItem "C:\\test\\srcScn2.max"
Listener reports:
<Interface:objXRefMgr>
<MixinInterface:IXRefRecord>
1
-- Error occurred in i loop; filename: S:\net_exe\scripts\maxscript\musevfx\_Referenced-Scripts\___WIP\XRef-Objects\_XrefObjUpdate_v.07.ms; position: 513; line: 14
-- Frame:
-- XRefObjectType: true
-- i: 1
** system exception **
OK
Also I notice that the "old" Xref record and the new are both listed still active, (srcScn1 record still holds the type->'Xref Controller', while srcScn2 now contains the type->'Xref Object. Assuming I need to find a way to move the controller and then use then use 'CombineRecords' to put them together after all Xref paths are set to be sourced from the same file?
I'm assuming I have two distinct problems here (one with the exception caused by my "for" formatting and another where I'm not changing the path on my controller). Hoping I'm close to a breakthrough on this, can anyone point me in the right direction?
I've been heavily referencing
http://www.cgplusplus.com/online-reference/maxscript-reference/source/in…
Thanks in advance!
-Eric
A big chunk of the solution...
Alrighty, changed up the way I was iterating bc it was causing the XRef record to freak out (moving entries out at bad intervals I think). Happily this works for swapping out Xref Objects under the entries:
This cleared up any system exceptions with type->'Xref Object.
Are there any brave souls who can help me with the matter of managing the leftover XRef controllers in the old entry? I can't find any reference to those in the docs, open to advice...
The alternative is to just give up on this "replacement" method and scrape out the old entry and replacing with the new, and than creating dictionaries for items (like Obj ID, etc.) I'd like to preserve between versions.
Thanks in advance for any help you can give.
-Eric
