Working Reference Coordinate System
By Gábor Miklós · 2013-11-27
So! I found that you cannot set the toolbar reference Coordinate System to type Working from maxscript, although the listener writes out that the working ref coord system command mode is #PIVOT, but if I try to use it, it doesn't work at all.
So if you write this command to the editor:
toolMode.coordsys #pivot
And execute it,
It says: -- Runtime error: Illegal coordsys mode type: #pivot
So is there any other way to change the reference coordinate system mode to working ref coord system in maxscript?
Gábor Miklós
HellYeah!
Thank you. I don't really know how you guessed it, but I really apprechiate it... ;) I tried to find it in the maxscript help, but nothing. So thanks again... :)
Are you try this
toolMode.coordsys #working_pivot
--or
WorkingPivot.UseMode = on
