I am trying to generate a Word Cloud.
I am reading an external file and getting the words and their
frequency of use successfully.
I am generating the words in Max and scaling them relative to their
frequency successfully.
But they are all piled on top of each other.
The problem I am having is figuring out how to place them in a plane
randomly, like a cloud, so they do not overlap but are close
together.
Any suggestions would be helpful.
Thanks.
this is an interesting topic! but its more an algorithm problem than a maxscript problem. you can use the boundingbox of your text objects
and their pivot to get their position and scale in the 3d space. you'll have to check their intersection
and place them accordingly, which is the tricky part, especially to do it efficiently. theres a lot of discussion and even some papers on the web, maybe it can help, Id didn't get it from a rough first look^^
http://stackoverflow.com/questions/342687/algorithm-to-implement-a-word-…
http://static.mrfeinberg.com/bv_ch03.pdf
http://www2007.org/workshops/paper_12.pdf
Yes it is an interesting problem
Thank you so much for pointing me in the right direction.
I have been scripting off and on for years, more off than on.
So I always feel like a beginner.
Thanks again.
