Wiring via. Maxscript
By Poker · 2009-08-23
Hey..
Im trying to wire the weights of a position controller to a custom slider added to a shape.
What i get from the listener is:-
paramWire.connect $CTRL_IK_Hand.modifiers[#Arm_Controls].ArmCA[#Blend] $.pos.controller[#Weight_IK] "Blend"
But it returns "-- Runtime error: connect requires subAnims", when I use this code.
I dont understand why it doesn't think the slider/weight is a subanim??
Luke Maskell
Had the same problem here with a Position Lists weights and wiring - and you solved my problem!
The listener kicked out:
$CC_RWristLock_Point.pos.controller[#Weight__Position_Constraint] "wristLock"
But it should have been :
$CC_RWristLock_Point.pos.controller[#Weights][#Weight__Position_Constraint] "wristLock"
Poker
found out that the listener outputted the wrong code for the the IK Weights. it "forgot" to name the weights command before, so the right one is:-
paramWire.connect $CTRL_IK_Hand.modifiers[#Arm_Controls].ArmCA[#Blend] $LowerArm_LookAt.pos.controller[#Weights][#Weight__IK] "Blend"
