Wirecolor script hep needed.
By ScriptSpot member · 2011-08-25
Hi friends,I am trying to do a script that toggles from a required color to previously assigned color .
For example
for i in geometry do
if i.wirecolor != black then
i.wirecolor = color 0 0 0
)else
--this should get the same wirecolor applied before running the script.
I am a neewbie in this field.And have got very limited knowledge.Hope to get help for my problem.
br0t
I've written something similar for materials once, so it was easy to adjust. You have to store the original wirecolors in an array. I wrote some comments into the script, hope it helps:
try(DestroyDialog ro_toggleWirecolors)catch()
rollout ro_toggleWirecolors "Wirecolors" width:151 height:34
	local theSel = #() --will hold the unique node handle of the selected objects and their original wirecolor
	checkButton ckb_toggle "Toggle Wirecolors" pos:[31,2] width:118 height:30
	colorPicker cp_targetColor "" pos:[-3,2] width:32 height:30 color:black
	on ckb_toggle changed state do
		if state then --if button is checked...
			theSel = for s in selection collect (#(s.inode.handle, s.wirecolor)) --fill the array with the handles and colors
			selection.wirecolor = cp_targetColor.color --apply one color to all selected objects
		)--end if
		else --if button is unchecked...
			for i in theSel do
				theNode = maxOps.getNodeByHandle i[1] --get the originally selected nodes by using their unique node handle
				if theNode != undefined do theNode.wirecolor = i[2] --make sure to check if the node still exists, to avoid a crash if it has been deleted; reassign original wirecolor
			theSel = #() --reset the array
		)--end else
	)--end on
CreateDialog ro_toggleWirecolors
Reply to br0t
amitananddey@gmail.com
Thanks a lot for spending your valuable time.I appreciate your effort in explaning it very clearly.Thanks a lot again.
