why there is no switching between move and scale modes in the example?
By andrej · 2018-12-10
Good afternoon. Can anyone explain why there is no switching between move and scale modes in the example? Any object and Point named Point001 is present in the scene
___________________________________________________________________________________________
try (DestroyDialog  Test) catch()
rollout Test "Test"
pickbutton pbtn_Select_Object "Select Object"
on pbtn_Select_Object picked obj do
select obj
max scale
toolMode.coordsys $Point001
toolMode.transformCenter()
createDialog Test pos:[100,100] style:#(#style_titlebar, #style_border, #style_sysmenu, #style_minimizebox)
_____________________________________________________________________________________________
I'm using Max 2015. After executing the script, the main Toolbar is set to Move, not to Scale.
andrej
Oh how difficult... But thank you for your attention to my problem
Switch to Select and Scale mode, execute this and pick an object in the scene:
rollout Test "Test"
As you can see right after the object is picked the Select and Move mode will be turned on.
Reply to miauu
andrej
I do not understand the answer.
Hello miauu!!! I do not understand the answer. How is my code different from yours? I even improved it. But the result is the same. Switching to SCALE mode does not occur.
rollout Test "Test"
select obj
    max move
max scale
Reply to andrej
As you can see in my code there is no need to have any code in the
It seems that no matter of the code in the picked obj event at the end the 3ds Max automatically turns on the Select and move.
This will do what you need:
rollout Test "Test"
	local pickedObj = undefined
	timer timer_01 "" interval:10 active:false
		timer_01.active = true
		pickedObj = obj
	on timer_01 tick do
		if pickedObj != undefined do
			max scale
			timer_01.active = false
