How can I weld vertices by threshold inside a group node?? I am writing a code which will attach all the same named objects (this part is already solved and discussed in this forum) and then weld the vertices by desired threshold (0.001)...it is working perfectly with geometries...but when those geometries are inside a "group"...it is not taling the thresold (welding is still working though)....since the threshold is an unknown property for group node. Any solution??
My code till now:
fn weldverts obj =
$.weldThreshold = 0.001
polyop.weldVertsByThreshold obj #All
newworking = #()
for o in geometry do
if classof o == editable_poly do
append newworking o
i = 1
while i <= newworking.count do
b = newworking[i]
j = i + 1
while j<= newworking.count do
if (newworking[j].name == b.name) then
b.attach (newworking[j]) b
deleteItem newworking j
select b
weldverts b
j = j +1
i = i + 1
I've learned all welding techniques upon enrolling in one of the prestigious welding classes here in Texas and I've gained so much knowledge from that. Welding is becoming more and more in-demand job here and abroad.
Weld by Threshold
weld = polyop.weldVertsByThreshold --keep interface operations outside for-loop
for o in geometry where isKindOf o editable_poly and not isGroupHead o do
o.weldThreshold = 0.01
weld o (o.verts as bitarray)
Thanks barigazy!!!
