Hello,
I have a script to clean up imported objects from AutoCAD. I wanted to add an addition to weld the vertices and add an auto smooth of 30 after it removes the isolated vertices in the scripts below.
any assistance would be appreciated!
Thanks,
Eric
sel = getCurrentSelection()
for obj in objects do
if iskindof obj Editable_Mesh do (
select obj
meshOps.removeIsolatedVerts(obj)
clearSelection()
selectmore sel
try this one
if getCommandPanelTaskMode() != #create do max create mode
with redraw off
for obj in objects where iskindof obj Editable_Mesh do
meshop.weldVertsByThreshold obj #{1..(obj.Verts.count)} 0.01
clearSelection()
select sel
Thanks!
Thanks for the script!
would it be possible to add an autosmooth of 30 after the weld?
I really appreciate the help.
-Eric
with autosmooth
with redraw off
meshop.autoSmooth obj #{1..(obj.Faces.count)} 30.0
clearSelection()
select sel
Thanks...
I am getting this error when running the script.
"-- Runtime error: Mesh vertex index out of range: < 1 or > 84: 85 <<"
