Weld Borders
By Marcelo Baglione · 2014-03-30
Hi! I can´t install Weld Borders in my 3ds Max 2013.
Can you help me, please? I don't get put the icon!!!
Thanks.
Gracias,
Marcelo Baglione, from Brazil, Rio de Janeiro
Marth Crowley
well i never got an icon either, so not exactly sure what you're looking for.
when you dropped the .mzp into your viewport did it ask you to install anything?
it should open up an install dialogue box.
if not, you can use 7zip to extract the mzp archive and manually install the script into your directory. It shouldn't be a problem unless you are using a differnet install directory than programs/autodesk/3ds max 2013
You can always search for the script by going into tthe customize menu, using all commands category and scrolling down to "WeldBorders"
if its not there, try manually installing it. Weld Borders is an .ms file, so you can drag and drop it into your MaxScript Editor and the ctrl + a to select all and drag it directly to a tool bar.
Marth Crowley
Hi
i just downloaded it, its an .mzp format,
so just drag and drop the file you downloaded into the viewport and it will automatically install.
the commands are under Customize > Customize User Interface >
Group: Main UI
Category: Nikkit Scripts
if you it doesn't install right you can use 7-zip to extract the contents and manually install the files in your max root folder.
Reply to Marth Crowley
Marcelo Baglione
Dear Derp Meowslurp, hi!
I don't get to activate the icon. I made several attempts. Script is working, but the icon doesn't appear; the Category: Nikkit Scripts doesn't appear, also.
Thanks.
