warning and continue dialog problem (and more)
By Ralf Bartsch · 2020-02-19
Hello,i got (another) problem with my script
if ((ssRoll != undefined) and (ssRoll.isdisplayed)) do (destroyDialog ssRoll)
Rollout ssRoll "GearCreator V0.3" (
	group ""(
		spinner sp_w "width" type:#float range:[0.0,10,1]
		spinner sp_h "height" type:#float range:[0.0,10,1]
		button bt_create "Create Gear"
	on bt_create pressed do(
		BPs = sp_w.value *sp_h.value
		if BPs < 0.999 then (
			rollout bgaRoll "GearCreator Warning"
					label lbl_1 "WARNING:"
					label lbl_2  "Blablabla"
					label lbl_3  BPs as string
					button bt_back "go back" width:82 height:24 align:#left offset:[2,10]
					button bt_forw "make anyway" width:82 height:24 align:#left offset:[92,-29]
					on bt_back pressed do(destroyDialog bgaRoll)
					on bt_forw pressed do (jump to line 29) and (destroyDialog bgaRoll)
			createDialog bgaRoll 200 116
				ss = rectangle name:"example" width:(sp_w.value) length:(sp_h.value)
	) --end create pressed
) --end rollout
createDialog ssRoll
q1- the 'on bt_forw pressed do' is wrong, but how do i continue anyway?
q2- the "BPs as string" is undefined. In my full script i use BPs a lott. should i write it easy time within the brackets, or is there another way?
tnx
	global ssRoll
		local BPs = 0
		group ""
		function CreateRectangle =
			if BPs < 0.999 then
					local lbl_3_text = ""
					label lbl_3 lbl_3_text
						ssRoll.CreateRectangle()
					on bgaRoll open do
						lbl_3.text =  (ssRoll.BPs as string)
				CreateRectangle()
	) --end rollout
	createDialog ssRoll
Reply to miauu
Ralf Bartsch
Ah,thank you again, Miauu. You are great.
(and you have enpasant another problem solved. I get confused with local/global a lott)
