Hi All,
I'm writing a HDRI viewer. Part of what I want to do is be able to read current HDRI's settings in the scene, specifically material editor slot 24. Here is the code I have so far on load:
if meditMaterials[24] != VRayHDRI() then
print "HDRI"
Hozmulti.value = meditMaterials[24].horizontalRotation
) else print "not"-- Hozmulti.value = 0
It only has to work from slot 24 and for the current HDRI if it exsits.
Think I've found a way around this using getMeditMaterial...
Whatever you call your VRayHDRI it will always have ":VRayHDRI" appended to it when you use getMeditMaterial. Therefore you can use the trimleft function to remove all characters that would appear before the ":". This way you can ascertain what's a VRayHDRI, and what isn't.
Appears a little fiddly but it's only two lines of code.
Cheers,
Alex
