VRay Render Element Parameters through MaxScript
By PerfectCell · 2012-12-04
I have just recently made my first ever MaxScript to speed up the process of sending renders, but want to add a little more automation to it, such as having it pull the camera clip values to use them in the VRayZDepth element.
However, I don't know how to access the VRay Render Element parameters through the code.
The same goes for Vray ExtraTex - assigning a texture to it etc.
Is there a list or resource somewhere that has the list of parameters/properties, or can anyone here help?
PerfectCell
not quite solved...
A colleague at work managed to track down this awesome resource which solves my problem!
Vray online reference
Actually, despite this list of properties, I'm getting 'Unknown property' errors...
Any advice?
- SOLVED -
Here's what I have right now, and it is working perfectly! :D
if n == vrayzdepth then
	i = findItem elementlist n
	re=maxOps.getCurRenderElementMgr()
	element = re.getRenderElement (i-1)
	element.zdepth_use_camera_clip_boudaries = true
