VRay material in 3ds max script
By maedeh mrdm · 2020-08-26
Hi everyone,
I'm new in 3ds max script. I want to define materials based on this document(https://docs.chaosgroup.com/display/VMAX/V-Ray+Illumination+Relevance+Te…)
I defined some standard materials in 3ds max script, But I don't know How I can set Vray materials in 3ds max script.
Another problem is about map an HDR image on a plane for the window's view out. how can I map HDR image on the plane without effect on interior lighting? Should I map this image in 3ds max script?
I will appreciate it if you help me.
Bests, Maedeh.
david
show Vray Material
Hi Maedeh, the material you want to create is vraymtl()
To see the properties of this material you can type:
show (vraymtl())
Another good method to see a materials properties and class is to add it to the Compact Material Editor (eg. slot 1) and type:
show medimaterials[1]
classof medimaterials[1]
