Hi all.
I have a problem beacause I'm not a pro in scripting and I need to create a little windows dialog in the Visual MAXScript. In this windows I have a slider and I must to connect this slider with an attribute holder wich control a dummy by a wire parameter. I'm not sure if I'm very clear ^^
So I made a little script but there is a problem and I don't know how to do.
If somebody can help me it will be really fantastic! :)
Thanks!
Here is my wonderfull script:
rollout unnamedRollout "Untitled" width:162 height:300
slider sld1 "Slider" pos:[8,8] width:141 height:44
on sld1 changed val do
$Circle005.modifiers[#Attribute_Holder].Custom_Attributes.Pied_Milieu = val
createdialog unnamedRollout
Comments (15)
It's really really cool of you!!! Thank you very much Barigazy for all your work!
It's perfect :)
I will send to you a picture when the project will be finish.
Have a nive day!
Thank you again!
Klemt
You must vizit this site if you already not.
http://paulneale.com/scripts.htm
For your rig the best solution is PEN Attribute Holder
Ok I will send to you all files ^^
Can you have your mail plz?
Really thank for all!
Pied Script
Hi klamt,
i finish your tool. See how to use it.
By the way, i don't speak french by i try
to make french version.Give me some credit for that :)
And this is your script
I hope that enough clear ^^
http://postimage.org/image/bgq9kevh7/full/
http://postimage.org/image/x4f7uuvvf/full/
http://postimage.org/image/qs02l0st7/full/
If you create manually controls for the Atribute_holder modifier then this is normal behavior, but if you not then look the line in my CA definition *on spn1 change val do ...*
how to connect modifier slider with rollout slider.
If you not understand this, send me a mail with a *.max file and *.ms for the rollout and if you have *.ms for the CA.
Another question: when I
Another question:
I use the first script with "Pied milieu".
So, when I activate "Auto Key" and I activate the slider, it created key on the timeline so it's perfect. But the sliders in the windows "Untitled" don't move when I move the timeline. How to link sliders to the timeline so that when I move the timeline, sliders moves too?
Whitch slider, again post screenshot
Yeah! It's perfect!
Thank you very much barigazy! :)
Klemt
My pleasure :)
script
Then use this script.
NOTE:As you see i have linked rollout slider with CA slider in
both way.
edit (second solution with example)
Ok.First, you need to execute this code for the scene creations.
Sorry for my poor english ^^
So, to simplify my request, I made a new scene with a sphere and a circle.
http://postimage.org/image/qejet8rpj/full/
The circle (Arc001) have an attribute holder. The spinner "Param1" control the sphere on Z Rotation.
How to connect the attribute "Param1" to "Slider"?
I hope it's more simple and clear ^^
Cordially,
Klemt
If you already make wire connection then this will help you
local ctrlObj
fn filterObj obj = isProperty obj "Attribute_Holder" and isProperty obj.Attribute_Holder.Custom_Attributes "Pied_Milieu"
slider sld1 "Slider" pos:[5,5] width:140 height:44 range:[0,100,0]
pickbutton pb_node "Pick Object" width:140 height:18 filter:filterObj
on pb_node picked obj do
if obj != undefined do
ctrlObj = obj
pb_node.text = obj.name
sld1.controller = ctrlObj.Attribute_Holder.Custom_Attributes.Pied_Milieu.track
if ctrlObj != undefined do ctrlObj.Attribute_Holder.Custom_Attributes.Pied_Milieu = val
createdialog unnamedRollout 150 85
You are not clear.Post a screenshot, to see whats do you need connect whit what
