Viewport Background Dialog question
By Branko Živković · 2012-04-24
How to check or uncheck "Use Viewport Background" checkbox in
the Viewport Background Dialog using the script?
Comments (8)
Pakwa Hicks
You can offer a series of images with different poses and positions. Perhaps leaning on a tree or sitting on the couch. Professional backdrops for photography with an eye to appealing to compose shots, so you can get a variety of shots to soften.
Raymond Homme Ingebretsen
Not sure what you are looking for ;o)
actionMan.executeAction 0 "617"  -- Tools: Use Gradient Colors Toggle
actionMan.executeAction 0 "618"  -- Tools: Use Solid Colors Toggle
actionMan.executeAction 0 "619"  -- Tools: Use Environment Background Toggle
actionMan.executeAction 0 "620"  -- Tools: Use Files Toggle
<boolean>viewport.EnableSolidBackgroundColorMode <bool>
<boolean>viewport.IsSolidBackgroundColorMode()
<ViewportViewSettingImpl>.UseViewportBackgroundEnabled : bool : Read|Write
  NEW in 3ds Max 2013: No effect.
<ViewportViewSettingImpl>.UseSolidColor : bool : Read|Write
Reply to Raymond Homme Ingebretsen
Hi tassel,
I know that max2013 have new option but I am currently writing a script for versions below 2013.
I try
but this only print in listiner
false
Look the image in the attachment
Jos Balcaen
viewport.DispBkgImage = true
you can do this with
viewport.DispBkgImage = false
Reply to Jos Balcaen
Not "Display Background" checkbox but "Use Environment Background"
at the top of Viewport Background dialog
You must assigne first a map as environment map and check "Use Map".
Then press "Alt+B".
Or simply run this
environmentmap = Gradient ()
useEnvironmentMap = on
max background display toggle
I did not know that this will be tricky one.
