hey all, well this is my last step at my character design so pls if any1 can help i'll be thankful, so, the problem is that i got an exporter, and when i export my object then import it again, the size will get back no matter i re-sized it before exporting, in other words, and for example, i got an object with let's say 100 units size, i rescaled it to 60, then exported, imported again, and no use, like i did no scaling, it gets imported with 100 u size again, but i tried a way to make a fixed size by scaling the vertex, and actually worked as for size, but it affected the motion very bad, so any suggestions??
Vertex Size change
By Devoti · 2010-11-11
Guess you have to reset your transforms before exporting. You can do this in max via the "Utilities" tab, "Reset XForm" -> "Reset Selected" and then convert your object to an Editable Poly or whatever again. If you have a skinned and animated character already, this might unfortunately cause you problems, best would be to reset the transforms before you start the rigging and skinning process.
well, it's already animated
i managed doing it :-)
