Variable = Variable
By Willian Kim · 2012-07-05
someone could help me with this?
I have the variable that equal a string with the otrher variables...
for exemple:
slot = 1
base = meditMaterials[slot].materialList[a].texmap_diffuse
    for a = 1 to 5 do (
           base = Color_Correction map:( base)
		base.rewireR = 0
		base.rewireG = 1
		base.rewireB = 2
		base.rewireA = 3
I want to be like this...
slot = 1
    for a = 1 to 5 do (
           meditMaterials[slot].materialList[a].texmap_diffuse = Color_Correction map:( meditMaterials[slot].materialList[a].texmap_diffuse)
		meditMaterials[slot].materialList[a].texmap_diffuse.rewireR = 0
		meditMaterials[slot].materialList[a].texmap_diffuse.rewireG = 1
		meditMaterials[slot].materialList[a].texmap_diffuse.rewireB = 2
		meditMaterials[slot].materialList[a].texmap_diffuse.rewireA = 3
But "base" not print meditMaterials[slot].materialList[a].texmap_diffuse, but yes the result this...
Thanks in advanced...
Garp
This should work:
[code]
slot = 1
base = mEditMaterials[slot]
for mtl in base do
mtl.texmap.diffuse = color_correction map:(mtl.texmap_diffuse) \
rewireR:0 rewireG:1 rewireB:2 rewireA:4
Reply to Garp
Willian Kim
Yeah man is very good, this loop is very much more functionally... but yet have the question...
Is possible define the variable with string with variable ?
for exemple?
base = meditmaterials[slot] != base = meditmaterials[slot]
I would like use a exemple: "base.texmap.diffuse" but " base = #Multi/Sub-Object:01 - Default" and not "base = meditmaterials[slot]"
understand?
Thanks very much...
Reply to Willian Kim
I TRY TO UNDERSTAND BUT ...
make a sceenshoot to see your problem
Reply to Branko Živković
Willian Kim
Hey ... I tried to summarize the problem...
I tried define the variable...
-- Type error: array index must be positive number, got: , got: undefined
but "slot" and "a" is a variable... How do ? Understand ?
thanks in advance...
