variable undefined in script: Copy_PathControled_Object_Along_Same_Spline.ms
By Chipley · 2007-10-22
Hiya,
I'm relatively n00b to MaxScript, today is my 1st look at ScriptSpot. I found a script that I'm very interested in using, but when I run the script, it tells me that the variable 'percent is undefined' per this line:
newLink.pos.controller.percent = (newLink.pos.controller.percent + (100.0/(NumberCopies as float)))
Easy enough error, but being new to MaxScript, I'm not sure how to define 'percent', so I was hoping for a lil' bit of help here to get me going. I've posted the entire script below, which is available at: http://www.hyperent.com/ - for those of you who have not seen the site before.
Thanks in advance,
~Chipley
--The mentioned script--
[DESCRIPTION]
This script will take ann object that is on a path (using a path controller) and make X copies of it along the spline.
[USAGE]
Select the object then run the script. The listener will come up and ask for the number of copies. Enter the number and hit enter.
[CREATION INFO]
Author:Paul Hormis
Last Updated: January 23, 2005
[VERSION HISTORY]
v1.00 Created
v2.00 Initial Public Posting
Copyright (C) 2004, 2005 Paul Hormis
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
paul@time-in-motion.com
OCLink = selection as array
OldLink = OCLink[1]
clearListener()
actionMan.executeAction 0 "40472"
NumberCopies = getKBValue prompt:"Enter the number of copies you want:"
for i in 1 to NumberCopies do
NewLink = copy OldLink
OldLink = NewLink
clearListener()
