validate the dialog box automatically
By JeremyA · 2018-04-18
I want to create an archive for each .max. I want to validate the dialog box automatically when I save.
I found "UIAccessor.PressDefaultButton ()" but I can not use it because my "max file archive" is pausing.
How to solve the problem? Sorry I'm starting =)
Thx
clearlistener()
thePath = getSavePath()--get a path dialog to specify the path
if thePath != undefined do--if the user did not cancel
  theFiles = getFiles (thePath+"\\*.max") --collect all max files in the dir.
  for f in theFiles do-- go through all of them
    loadMaxFile f--load the next file
-- MAKE SOME SCRIPTED CHANGES TO THE SCENE HERE...
	max file archive
-- 	actionMan.executeAction 0 "40085"  -- File: Archive
--     saveMaxFile f --save the file back to disk
  )--end f loop
  resetMaxFile #noPrompt --at the end, you can reset
)--end if
Comments (8)
JeremyA
Actually, I've already looked at the documentation but it's not easy. I tested 2 method, but I have the same result. A window appears "Dialog Monitor" he asks me "Close the Dialog?" answer "Yes" or "No". Am I on the right track? I do not understand very well
Method 1
DialogMonitorOPS.Enabled = true
max file archive
uiAccessor.pressButtonByName hwnd "Save"
DialogMonitorOPS.Enabled = false
Method 2
clearlistener()
DialogMonitorOPS.unRegisterNotification id:#savecustom
-- my function for handeling the dialog
fn mf = (
	-- Get the window handle of the current dialog
        windowHandle = DialogMonitorOPS.GetWindowHandle()
        UIAccessor.PressDefaultButton()
	return true
DialogMonitorOPS.RegisterNotification mf id:#savecustom
max file archive
Reply to JeremyA
Panteleev Sergey
DialogMonitorOPS.UnRegisterNotification id:#maxArchive
fn handleZIP = (
	local hwnd = DialogMonitorOPS.GetWindowHandle()
	if hwnd == undefined do return true
	local data = windows.getHWNDData hwnd
	if data[5] == "File Archive" do (
		for c in windows.getChildrenHWND data[1] do (
			format ">> %\n" c
			if c[4] == "Edit" do (
				format "- - - - - - - - - - - - - - - - - - -\n"
				UIAccessor.SetWindowText c[1] "someFile.zip"
				UIAccessor.PressButtonByName data[1] "&Save"
				if ::ForceArchiveOverwrite do UIAccessor.PressDefaultButton()
	true
global ForceArchiveOverwrite = true
DialogMonitorOPS.RegisterNotification handleZIP id:#maxArchive
max file archive
Thank you very much for your code. It works very well. I just removed this:
I needed to have the same name as the .max scene
Could you explain to me please? I would like to try to understand the reasoning.
Thanks again :)
Therefore, for my batch zip:
clearlistener()
-- print (windows.getChildrenHWND #max) -- scanner tout l'interface pour avoir le code des btns
	-- ZIP	START
	fn handleZIP = (
				format ">> %\n" c
	-- 				format "- - - - - - - - - - - - - - - - - - -\n"
	-- 				UIAccessor.SetWindowText c[1] "someFile.zip"
		true
	max file archive
	-- ZIP	END
  )--end f loop
)--end if
Sorry, I badly expressed myself, I wanted you to explain your code, not "maxscript reference scene filename". File archive already use the scene name. That's good ;)
Reply to JeremyA
Panteleev Sergey
Well..
1. check if there's a window handle
2. get window data
3. check if window has appropriate title
4. iterate over window child controls
5. if child control is "Edit" then set archive filename and press Save
6. handle (or not) overwrite popup if directory already contains zip with such filename
7. unregister dialogmonitor
Vojtech Cada
Check the DialogMonitorOPS topic in maxscript reference, they're designed to catch the dialog and if it matches the criteria you set, you can then press the default button.
