UVObject = #()
if (selection as array).count != undefined then
UVObject = (selection as array)[1]
tst = #()
for h in UVObject.modifiers do (if classof h == uvwmap then (append tst h) )
if tst.count != 0 then
modPanel.setCurrentObject UVObject.modifiers[#UVW_Map]
subobjectLevel = 1
dear friends
i made this code for uv move
but that is still error
what problem ?
code erro2
thank you for good reply
$.pivot = $.center
$.modifiers[#UVW_Map].gizmo.position = $.center
i add this code too
but error ?
postion is diffirenet
sure. cause it's a relative position
i test it
i test your code
but still , gizmo can;t move correct position ~~~
ps : i test again
if i reset xform object . postion is correct
thank you
check mxs reference
if selection[1] != undefined do (
uvwmaps = for m in selection[1].modifiers where isKindOf m uvwmap collect m
for uvw_map in uvwmaps do uvw_map.position += random [-1.0,-1.0,0.0] [1.0,1.0,0.0]
