Using objects created in an if-loop, lateron in that same loop
By Ralf Bartsch · 2008-12-20
Hello,
I'm still working on my script (some topics ago i had a question) And i got stuck agian. Im trying to create a moon...its orbit around a planet moves ofcourse with the planets orbit. So i want either
1) to path-constrain orbit1 to orbit2, or (the better option)
2) to link the orbit to the planet.
Problem here seems (aside from the syntax which i still have trouble learning) that this parent-orbit or parent-planet is created in the same if-loop.
the next loop works just as expected, all orbits are centered around [0,0,0]...... sofar so good
/* ExampleArray = #(name,center,type,other) */
Plt = #(#("Jupiter", "Origin", "Planet","Other Properties"),\
#("Io", "Jupiter", "Moon","Other Properties"))
for i=1 to Plt.count do
   orbit1 = ellipse()
   orbit1.name = "Orbit of " + Plt[i][1]
--some more lines setting properties of Orbit1 here i left out for easy reading
   globe = sphere()
--some more lines setting properties of globe here i left out for easy reading
   globe.pos.controller = Path_Constraint()
   globe.pos.controller.path = orbit1
Now, i'd like to get the moon-orbit to move around the orbit of its parent Option1). i could just create a seperate ellipse for this, but that would mean is get multiple identical ellipses. I'd rather select and use the existing one. The next script doesnt work...
i have an idea why, but don't know how to do it right
	orbit1 = ellipse()
	globe = sphere()
   if Plt[i][3]=="Moon" do (
	PPath = Max Select "Orbit of " + Plt[i][2]
--this previous line is obvious the problem
	orbit1.pos.controller = Path_Constraint()
	orbit1.pos.controller.path = PPath
I tried some variations on the next loop aswell. This gave me the impression i cannot select anything created earlier in the "for i=1 to Plt.count do"-loop until the whole loop is finnished. is that correct?
if Plt[i][1][2]=="Moon" do (
		LC = Link_Constraint()
		Parent = Plt[i][2]
		orbit1.controller = LC
		orbit1.transform.controller.addTarget $Parent 0
Could anyone please help me out a bit?
Ralf Bartsch
ah, great, this is gonna help me to make some major improvements during the holydays.
(i did indeed download v1 2 times... i was wondering)
You're right. Moon-orbits don't rotate with the parentorbit, the major-ax is 'fixed' wrt the stars. I already got the shape and orientation of orbits and planets working. It wasnt very hard, and left it out of the code in my 1st post.
For the animation i got an input for a start and end date(y/m/d), plus an accuracy-slider (hours/frame) which now work 95%. Only the non-constant velocity has yet to be implemented, but i got the formula's from kepler, and a good idea how to do it.
I'll post the 'results' after newyear. i dont have the illusion that it will be finnished, but i hope to make some good progress over the next couple of day's
Before i became a modeler i studied astrophysics for a few year, so this was a nice case to learn MaxScript by. ofcourse not the easiest case (typical me)
But it keeps me thinking about it around 24h a day :) ... and it's great to know someone else can get entusiastic about it aswell.
tnx again Anton :)
Anton Berg
made another version with some added animation just for fun ;-)
I really can´t let this project go... it is fun. Will be interesting to see your final result!
Anton Berg
Have you looked at v03 of my script? You should be able to add x amount of planets and n amount of moons connected to every planet.
But I create a separate path spline for all the moons. I am not sure but the moons of a planet dont follow the same spline do they or?
regaring your first script: you typed this..
if you would like to store an objectname in the variable PPath you need to make it into an object refence again.
Example:
PPath = $myplanet --this is a direct reference if you know the name
-- If you need to dynamically access the name do
myName = getNodeByName ( "Orbit of " + Plt[i][2])
--the getNodeByName takes a string as an input and returns
--ALL nodes with that name... so you might get several
--answeres if you dont name your objects correctly
--ex it might evaluate to:
PPath = $Orbit of Jupiter
I used the execute command in my v02 of this script but then I realised that it Doesnt handles spaces in object names like "Oribt of xxx" would not work OK with execute. It would think that "of" and "xxx" was commands.
Ralf Bartsch
tnx, i'm going to try some of these things when i get home, but i'm worried it won't fix the problem.
Thing is, in you're example you create the planet 'global' and then 'link' the moon to it (orbit2.pos = abplanet.pos)
That would be fine if there where only 2 objects or so, but my array contains over 100 objects...and i want end-users to add more if they like. (with the restriction the parent is always created before the child) So i have (and want) to use an if-loop.
This way the parent is created 'local' in loop-iteration i and the child in i+1.
So i think i have to get the parent out of the scene. If this is impossible i could re-organize my array, but i'd rather adjust the code (for flexabilaty-reasons).
Anyway, i'm gonna try some of your code (or what it inspired me to) and get back on it tommorow.. tnx sofar
Anton Berg
A made a small example script with a simple example of how to build the system up... check it out and let me know if it helps or doesent ;-)
By the way... one thing that is "problematic" in maxscript is to store object names as a string and later access them again. This is probably the most common place to use the execute command (which is very expensive to use) so you could convert a string: "$myobjectname" into $myobjectname without the quotes!
Happy maxscripting!
By the way how do you get the input data for this? Do you have a textfile or database?
Anton Berg
If you to link the position of a path to another object I would recommend the:
$myPathName.parent = $thisIsTheParentObject
I dont think you need the Link_constraint unless you need to do some vary complex variable linking.
I am looking at the other "problem" to see if it as a good way of solving this but I just thought I should write something about the .parent instead of link_constraint first.
just open my small example script to se it in action.
