updating simpleMod
By Jos Balcaen · 2012-04-24
I'm scripting a simple modifier. When picking an object i want to display the name of the picked object on the pickbutton.
on pcbSourceObj picked obj do
doesn't work. same for (button,spinner,..) Also i want to update the modifier when changing a value.
Is there a way? Thank you
plugin simpleMod test
classID:#(0x7e4dd50a, 0x2577a8c0)
version:1
	parameters main rollout:params
		spinnerval type:#radiobtnindex ui:spnTest
		sourceObj type:#node ui:pcbTest
	rollout params "Mirror Parameters"
		pickbutton pcbTest "pick" width:150 height:30 align:#center
		button btnTest "Test" height:30 align:#center
		spinner spnTest range:[0,100,1]
	on btnUpdate pressed do print "btnUpdate pressed"
	on pcbSourceObj picked obj do print "pcbSourceObj picked"
	on spnTest changed val do print val
	on map i p do
Maybe this you want
if obj != undefined do pcbSourceObj.text = obj.name
orpickbutton pcbTest "pick"
or pickbutton pcbTest "pick" width:150 height:30 align:#center autodisplay:true
- it updates automatically
you can also use the [on value set do ()] event inside the parameterblock.
See scripted primitives clauses in mxshelp
Reply to kilad
Jos Balcaen
thanks! the autodisplay:true
thanks! the
autodisplay:true
works perfect.
when I place
on value set do (print "value set")
inside the paramterblock it doesnt print anything...
Reply to Branko Živković
Jos Balcaen
doesnt work
the handler
doesnt work. It doesnt print anything (see my code)
