Hello,
is there a problem with .numberVertices() command ?
make an object apply unwrap modifier, break some faces then weld them together and run the script.
trying to select a vertices that is higher than max select all command will result in selecting an invisible vertex.
I appreciate if someone could guide me if i'm doing anything wrong thanks
curSel = selection[1]
curMod = modpanel.getcurrentobject()
curindex = modpanel.getmodifierindex cursel curmod
-- numMapVerts = curSel.modifiers[curindex].numberVerticesByNode curSel ()
numMapVerts = curSel.modifiers[curindex].unwrap.numberVertices()
curSel.modifiers[curindex].updateview()
format "NumberVertices Command : %\n" numMapVerts
max select all
myArray = curSel.modifiers[curindex].getSelectedVertices() as array
format "All Vertices Selected : %\n" myArray.count
max select none
