--Unknown system exception
By Script_Butler · 2011-07-01
Hi all,
I've been developing my Mulsi/Sub Object MAterial Script but when I run it i get the above error........
Here's the code
rollout a "Create" width:200 height:496
	button btn_1 "Create" width:80 height:25
	button btn_2 "Create for VRay" width:90 height:25
rollout b "About" width:200 height:200
		label lbl1 "Multi/Sub-Object Presets v0.5" pos:[48,8] width:112 height:16
		label lbl2 "Created by Andy Butler" pos:[23,24] width:160 height:16
		HyperLink homepage "SB_Tools" pos:[70,56] width:65 height:15 address:"http://www.scriptspot.com/users/script-butler/" color:(color 255 255 255) hovercolor:(color 255 0 0) visitedcolor:(color 255 153 51)
		label lbl3 "Copyright © 2011" pos:[58,40] width:83 height:15
		on btn_1 pressed do
			mat = multimaterial()
				mat.count = 10
				mat[1] = standardmaterial name:"Standard 1" diffusecolor:[255,0,0]
				mat[2] = standardmaterial name:"Standard 2" diffusecolor:[255,125,0]
				mat[3] = standardmaterial name:"Standard 3" diffusecolor:[255,255,0]
				mat[4] = standardmaterial name:"Standard 4" diffusecolor:[125,255,0]
				mat[5] = standardmaterial name:"Standard 5" diffusecolor:[0,255,0]
				mat[6] = standardmaterial name:"Standard 6" diffusecolor:[0,0,255]
				mat[7] = standardmaterial name:"Standard 7" diffusecolor:[0,125,255]
				mat[8] = standardmaterial name:"Standard 8" diffusecolor:[0,0,255]
				mat[9] = standardmaterial name:"Standard 9" diffusecolor:[125,0,255]
				mat[10] = standardmaterial name:"Standard 10" diffusecolor:[255,0,255]
				meditmaterials[activeMeditSlot] = mat
	on btn_2 pressed do
					mat.count = 10
					mat[1] = Vraymtl name:"VRay 1" mat[1].Diffuse = color 255 0 0
					mat[2] = Vraymtl name:"VRay 2" mat[2].Diffuse = color 255 125 0
					mat[3] = Vraymtl name:"VRay 3" mat[3].Diffuse = color 255 255 0
					mat[4] = Vraymtl name:"VRay 4" mat[4].Diffuse = color 125 255 0
					mat[5] = Vraymtl name:"VRay 5" mat[5].Diffuse = color 0 255 0
					mat[6] = Vraymtl name:"VRay 6" mat[6].Diffuse = color 0 0 255
					mat[7] = Vraymtl name:"VRay 7" mat[7].Diffuse = color 0 125 255
					mat[8] = Vraymtl name:"VRay 8" mat[8].Diffuse = color 0 0 255
					mat[9] = Vraymtl name:"VRay 9" mat[9].Diffuse = color 125 0 255
					mat[10] = Vraymtl name:"VRay 10" mat[10].Diffuse = color 255 0 255
	rof=newrolloutfloater "Multi/Sub-Object Mat" 216 600
addRollout a rof rolledUp:true
addRollout b rof rolledUp:false
Would you be so kind to tell me why i get this error?
Cheers.
Script_Butler
I'm so stupid!
I will get the hang of this eventually!
Thanks Anubis.
keep attention to the scope
now your button events are out of the rollout scope, shortly:
	button btn_1 ...
	button btn_2 ...
	on btn_1 pressed do
	on btn_2 pressed do
