Unknown property... Please help, newbie issues -.-
By michael · 2012-09-06
>> MAXScript Rollout Handler Exception:
-- Unknown property: "castShadow" in $Editable_Mesh:subMeshTest002 @ [-5.230925,6.493752,0.000000] <<
 "castShadow" in undefined <<
"castShadow" in Editable_mesh <<
I understand that Unknown property is a common problem.. But the reason why I'm posting about it is that I have make a check statement to see if the attribute exists.. and it's crashing because the attribute doesn't exist -,- which is counter intuitive. Also, for that object there was that custom attribute, so it didn't find it for some reason :(
if( objects[numNodes] == undefined) do continue
body = objects[numNodes] -- collision body to export
-- code emitted to save space
if body.castShadow != undefined then -- this right here is causing the exception.. but it's supposed to be checking for existance.. which non existance should be an acceptable outcome
--do stuff
the custom attribute is defined here:
newAttrib = attributes entityAttrib
	parameters posParam rollout:entParams
		xPos type:#boolean ui:castShadow checked:false
	rollout entParams "Entity Atributes"
		checkbox castShadow "Casts Shadows?"
custAttributes.add $ newAttrib
Maybe i'm doing this all wrong.. maybe somone can tell me the correct way to do the following:
I'm trying to add a rollout to object's to allow you to have custom properties which later my level (xml) exporter goes through all objects, it the attempts to see if each of the objects it is running through has the custom attribute, it will then add an xml node for that attribute if it existed... I might just resort to manually adding object properties, but that's not desirable and will also not solve the error mentioned at the start.
FULL SOLUTION:
-- THIS IS THE SOLUTION FOR ATTRIBUTES:!!!
$.baseObject.entityAttrib.castShadow = on
isProperty $.baseObject #castShadow
and the solution for the exporter
change this:
--do stuff
TO THIS
if isProperty body.baseObject #castShadow == true do
     format "\t\t<castShadow> % </castShadow>\n" body.baseObject.entityAttrib.castShadow to:currentFile
FOR HELP LEARNING MAX SCRIPT:
EDIT: omited plausible illegal link
Also theses forums have many answered questions about maxscript
http://forums.cgsociety.org/forumdisplay.php?f=98
http://www.polycount.com/forum/
http://area.autodesk.com/forum/autodesk-3ds-max/maxscript/
Comments (8)
michael
if body.baseObject.entityAttrib.castShadow != undefined then
is now causing this error:
-- Unknown property: "castShadow" in entityAttrib:entityAttrib <<
You need to use this
$.baseObject.entityAttrib.xPos = on
--or if you want to check it have the property use
isProperty $.baseObject #xpos
--true
ok.. problem one fixed... my code is now this:
still, the property does exist.. it's just not working
Reply to michael
If you want to use #castShadow property then you need to change
CA definition like this
castShadow type:#boolean ui:castShadow checked:false
--and then use >>
It worked.. Thank you very much... btw, if you were gonna try and solve problems what would u rely on other than the help file in 3ds or ur experience.. Like is there a good resource of examples?
by good, i mean, what would u use
Reply to michael
michael
also, thanks for the fast and good replies.. A site like this with such good people on it is rare
Reply to michael
Yep.I share your opinion.
I also send you a mail
Cheers man!
